Thread: Exhaust heatshield
    Central Scotland
    Default Exhaust heatshield
    Hi all,
    finally traced a rattling noise in the car today to the centre heatshield above the centre section of the exhaust. The aluminium plate has corroded through and fallen onto the exhaust. I tried to remove the nuts and ended up shearing the rear two studs off the subframe, great fun.
    Has anyone else had this problem and how did you fix it? I was thinking that the easiest method would be to drill and tap the subframe and make up some large aluminium washers to refit the heat shield. Ideas anyone?
    Regards
    Ian
    Jan 2006
    Skynet HQ EMEC#5
    I had the same problem, but only 1 side. The problem is because of of the metal being so thin & not a very wide washer on the nut.
    What I did was wire brush the threads, spray some wd40 or similar on.
    Then move the nut a small amount either way until it moves easily.
    I only snapped 1 because I was too keen.
    What you need to do then is get some wider flat washers to sit over the worn part to hold it all in position.
    Central Scotland
    Tried the wire brush and WD40 route. Even tried running a die nut up the threads but still snapped them. Looks like I wil have to cut down on the wheatabix for breakfast.
    Ian
    spoons
    Guest
    I've just cut mine out !!!
    Regular Member denzo's Avatar
    Runcorn
    Glad you found your rattle ... i posted the heatshield as a cause for my annoying rattle a few months ago.
    Luckily my nuts were loose - I removed them and replaced with Stainless Steel Self Lockers with some nice washers.
    Hope you get yours sorted
  1. For Sale: Z19dt turbo heatshield
    By tommytonguedj in forum Parts for sale
    Last Post: 4th May 2012, 10:17
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. replacing a heatshield.....
    By corman in forum Bodywork & Interior
    Last Post: 22nd January 2009, 22:45
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
