Thread: 4th service Question
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default 4th service Question
    My car is having the firing on 5 cylinders sorted, and i want to have the service done at the same time, its having the 4th service done, what do VX change and check on the 4th service? My car has done 53K and had the Cambelt changed at 38K
    Regular Member jammydodger's Avatar
    lancashire
    have they told you what is causing it to run on 5 cylinders !
    S.Wales, Nr Swansea
    Faulty Spark plug, would you believe it
    lancashire
    You just don't think of the obvious sometimes mate, but how often do you hear of faulty spark plugs. never mind at least it was a cheap fix!.
    A guy i used to work with once bought a mini engine from a scrap yard cos his had blown up. when he got it home he fitted new plugs air filter oil etc and put the engine in fired her up misfired like hell. he checked everthing no joy so pulled the engine out took it back and the bloke said take another no problem. he get home fits the engine without doing anything to it and it runs fine puts the new plugs in and ........ misfire. He had 2 faulty plugs and as expected was a bit peed off.
    S.Wales, Nr Swansea
    lol, well VX told me to have the 4th service done, the service is due next week anyway, and they wont charge me for finding the fault and just replace the plugs with the service...Result!
    lancashire
    that is a result, hopefully they wont find anything expensive on your 4th service, your cars a peach by the way, and i would keep the vxr wheels
    Quote Originally Posted by 3.2_V6_VXR View Post
    Check back in the service history, depending on if your service history is time intervals or mileage dependent then I would have thought the servcie at 38K miles would have been a major one and included all service components including spark plug renewal interval
    If they were indeed replaced at that service, then they should be covered by 12 month warranty
    My previous Vectra 2.0 had the spark plugs replaced at 40K mile service intervals, along with the cambelt kit and all other service components
    Expensive, but cheaper in the long-term
    S.Wales, Nr Swansea
    The cambelt was changed by the previous owner at VX it wasnt done during the service
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Isn't spark plug interval 80,000 miles??
    53K and up for 4th service??? Is 3.2 service interval shorter than others??
    S.Wales, Nr Swansea
    No its every 20k but since ive had the car i want it done every year
  1. Service question
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 13:04
  2. Service question...........
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2008, 22:14
  3. Service Question - Oil
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2007, 21:07
  4. Sorry but Service Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2007, 11:57
  5. Hi again + 2nd Service Question
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2006, 17:23
