Results 1 to 10 of 30
Thread: Spanner light
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Spanner light
    Only had the car a week but i noticed a knocking noise yesterday , only did it once near home, when i used the car about 20 mins later the spanner light came on while driving, it now only comes on when i first turn the ignition on and goes out when i start the car.
    Earliest for the dealers is Monday, had the car inspected at Kwik Fit and they could see nothing wrong with springs or suspention at all.
    My question is would it be safe to drive with the spanner light coming on when you first put the ignition on ?
    The manual dosent really say much
    Its a SXI CDTI 120 , 54
    Full Member Big Sig's Avatar
    It should be ok to drive with the spanner light on as you say. Its only not safe to drive when its flashing all the time. If it comes on and stays on with out flashing then the car is in limp home mode. hth
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Ok thanks m8, got a few local journeys to do this weekend
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Had the light on briefly yesterday, when driving, for the first time. Manual says if it comes on briefly and then goes out it is of no consequence. You will know it if it goes into an emergency running programme (limp mode).
    Jul 2006
    When it comes on with the ignition, it's simply a reminder that the ECU has stored fault codes. If the engine successfully starts 25 times (i think) without the same fault reoccurring, it will cancel the fault code by itself and you'll have no more EML.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by parapaul View Post
    Thanks a lot Paul, didn't know that.
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Thanks for the replies, is it worth still taking it to the dealers on monday do you think or should i start the car 25 times to clear it
    if its covered, take it in
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    I didnt know that either, my light came on the other day then a couple of days after and noticed the light stayed on with ignition. Went to dealers and had a new fuel pressure regulator fitted under warranty (13000 miles) and now the light is off with ignition so that makes perfect sense!
    I used to work with petrol injection and have been out of it for 2 years and everything is changing lol!
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Quote Originally Posted by Astrase20 View Post
    Covered until December
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
