Thread: Map reading light.
    Chester
    confused Map reading light.
    Couldn't see this in the How to section so.....
    Is it easy to do?
    How is it done?
    Washington
    From what I vaguely remember, remove the clear plastic casing on the existing light and undo 2 torx screws, then unclip the alarm sensor behind of the light, then unclip the blank plate infront of the existing light (some have fitted sunglass holders here) and slide the whole light unit out, then unclip the cables, making a note of whcih way things go back in. Fitting the new light is the reverse. Something like that anyway.
    Chester
    Quote Originally Posted by ace View Post
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Just done mine , its easy to do pull the unit from nearest the windcreen downward and it will slide out, when the 3 torx screws are loose
    If you are fitting the sunglasses holder i found it easier to fit it in the map light before refitting it as it didnt click secure when the maplight was in situ in the car.
  1. Interior map reading light!
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2009, 18:41
  2. Map reading light and sunglasses
    By malk in forum Styling
    Last Post: 28th April 2009, 16:13
  3. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
  4. Map reading light
    By GARY3306 in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2006, 23:52
vectra c map reading light
