Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Thread: help! spanner light! 2.0dti
    May 2007
    Grays Essex
    confused help! spanner light! 2.0dti
    driving home yesterday my spanner light came on twice,each time i lost power carried on for a further 10 miles with no light on then on it come again but this time loads of blue/white smoke and no power pulled over and waited for RAC 1 hour later tried to start her and there was no spanner light and no smoke since then its been ok,after getting home and having a look under bonnet all that i could see was the turbo intercooler pipe was soft and kinked has this happened before to any one else help please!!
    the first thing you need to do is inspect the intercooler hoses for small splits..that would cause the spanner light...get the fault codes read as well to tell you what the fault is if you fin no splits.
    May 2007
    Grays Essex
    thanks but there are no splits or leaks so i am puzzledi soppose its off to the stealers then
    yep, or any independant who can read CANBUS cars..
    May 2007
    Grays Essex
    Unhappy spanner light fault fixed!
    well after a visit to the stealers and charging me £39 for reading fault codes then a further £80 because it needed longer on the tech2 to find fault they told me it needed a new throttle body total bill came to £380! touch wood it seems to have fixed it but why should i have to need a new throttle body on a car that has only covered 30,000mls!!! PS its a 2.0dti 2004.
    i have also heard of fuel pumps going on the vec diesels can anyone tell me what engines have the fuel pump problem and from what year,milage covered before they give up the ghost???
    Feb 2007
    Wolverhampton
    Had this problem last month, on way to Leeds on my 2.2 Dti, spanner on, no turbo. Pulled on to hard shoulder, turned off engine, had a wee! Got back to car started fine no spanner and has been fine since, should i get it checked out anyway just in case? Anybody know off an indy that can read CANBUS cars in the black country/birmingham area?
    Mick p, my 2.0 dti is on 117,000 mls, i've seen them with over 200'000 mls and still going strong, the pumps aren't a common problem if you look after them, only use good quality derv like shell and i use millers sport 4 for added lubrication ( oooh missus ), They had a few probs with the earlier ones on the vec B but were improved on the C.
    Belfast
    Throttle body on a 2.0DTi? They conned you.
    May 2007
    Grays Essex
    well ZS you say i was conned can you tell me how much a throttle body should have cost me?
    Admin plasma's Avatar
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    think he means they dont have a throttle body mate,
    Throttle body is for petrol engines afaik
  1. Car Spanner Light 2.0dti
    By holtie in forum Engine & Drivetrain
    Last Post: 17th January 2013, 16:37
  2. spanner light on no power 2.0dti
    By postman111 in forum Engine & Drivetrain
    Last Post: 11th February 2012, 23:15
  3. Spanner through Car warning light - 2.0DTi
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 18:11
  4. spanner light on my Signum 2.0DTI..help pls
    By cermi in forum Engine & Drivetrain
    Last Post: 5th December 2009, 08:38
  5. 2.0dti - spanner light syndrome!
    By Littleted in forum Engine & Drivetrain
    Last Post: 10th January 2008, 00:23
