Thread: CIM module
    Regular Member rayvo-gsi's Avatar
    warrington
    Default CIM module
    Anybody know if this is just a straight swap (without ignition barrel)and will 1 of a 2.2SRI fit on a 3.2GSI.I beleive its on the steering column
    Feb 2007
    Glasgow
    No, it's not a straight swap
    The CIM is coded to the car and also holds your cars keyfob information. If you put another one on, your car won't start.
    Needs Tech2 to program in your cars information, then learn your keycodes again. Also needs to have been reset when removed from the donor car before you can do any of this.
    I'm guessing that the 2.2 and 3.2 use the same module, but I'm sure somebody that knows for sure will be along soon...
    yep.. it needs programming to the car...you can't just swap them over..
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i had the same problem with mine. brought a second hand one for £30 delivered because my squib was no good, so i thought il just change them over went to start the car and nothing phoned a deal and the said it was no good and throw it away and buy a new one at £250 programed. so went home had a good look a besided to take it apart a just change the squib it took all of 20 mins. dealer said it cant be done proved them wrong.
    if you have all the info from the other car ie vin number key code imob code and it could be done via tech 2
    warrington
    Cheers for the info guy's my clocks keep going to zero quite annoing
  1. Can someone tell me where the BCM module is?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 16:41
  2. cim module anyone
    By triplecrown31 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2012, 22:54
  3. CIM module
    By SimonSinkovec in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2010, 11:16
