Thread: rear washer not working??
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    Default rear washer not working??
    I have noticed the other day that my rear wash wipe does not work...
    When standing outside the car I can here the motor trying to pump the water.
    I have used a pin to try and unblock the jet to no avail....
    Is there a seperate reservoir for the rear washer????
    stuck now as did not want to start ripping out the head lining to get to the bottom of the Jets
    Are your front jets working ?????
    If they are not or are not very good then it sound's like your washer pump has blocked up quite common fault there is only one washer bottle on the vecy under the bumper passenger side pull out the pump's and they have a small gauze filter over the end (sometimes stays in bottle) take this out and clean it should be job done if not sound's like a blockage in the line somewhere !!!!
    Quote Originally Posted by Drinky View Post
    yeap front jets working no problems at all. i have cleaned the rear as much as i can but is it easy taking off the rooflining to clean out the rear jets properly and see if water is getting through..
    Regular Member David_SRi_2.2DTi's Avatar
    Jun 2007
    Leeds
    This happened to me too. Turned out a break in the water pipe under the wheel arch
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 187000
    i had it on mine too about a year ago, the fronts were working fine but the rear didn't. i could smell the screen wash inside the car so i took it into vaux turned out a pipe had come off
    Jan 2006
    Cardiff
    Same here, with mine it was a little rubber seal in the elbow joint thats connected to the pump, it was obstructing the flow, so pulled it out together with a plastic ring replaced the plastic ring and elbow working fine.
  1. washer jets -NOT WORKING!
    By nim-nim in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2011, 18:52
  2. Washer Not Working
    By Hollingsworth87 in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 15:15
  3. window washer not working
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 15:29
  4. Washer jets not working on 2.2dti
    By jazzy_2.2dti in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2006, 08:38
  5. Help, my rear washer isn't working
    Last Post: 9th July 2006, 10:51
vauxhall vectra rear washer hose
vectra c 2005 rear wiper not working
vauxhall vectra rear washer not working
how to replace the hose to the rear washer on a vectra c
signum rear washer problem
rear washer not working vauxhall vectra c
vectra c rear sprinkler
vauxhall vectra washer tube in head lining
rear wiper washer not working 54 vectra
back washers on Vectra not working
vectra c rear window washer not working
vectra c rear washer not working
how to remove rear washer jet on vauxhall vectra c
