Results 1 to 10 of 20
Thread: Brake Light Switch Removal
    Regular Member Mowster's Avatar
    Cornwall
    Default Brake Light Switch Removal
    Hello Everyone, I have had a problem with the brake lights staying on whilst driving. They sometimes flicker but more often than not they are constantly on. Narrowed the problem down to the brake light switch underneath the brake pedal. I know this because when I tap the switch the brake lights go off. My questions are, how do you remove the switch? it does'nt seem to just pull out , also a part number would be good if anyone knows. Thanks for any help.
    Cornwall
    Back to the drawing board !! I replaced the brake switch but the brake lights are still on constantly. Must be a short somewhere. If anybody has had the same problem could they let me know how they fixed. Many thanks.
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Have you checked the brake pad wear sensor? Quite common for the lead or sensor to get damaged, especially when changing the pads. Might also mean the pads are worn. Easy to change and they are only around £10 from a dealer.
    Edit: Should be on the near-side front wheel, lead comes from the caliper and up to a bracket/connector on the strut.
    Cornwall
    Thanks Spikey but would the brake pad wear sensor cause the brake lights to be constantly on. To clarify, I dont mean the warning light on the dash, I mean the actual brake lights.
    Dec 2005
    D'oh! Sorry dude, read it as the light on the dash
    Cornwall
    Thats ok mate, thanks anyway.
    Southampton
    Probably talking out of my ****, but I thought I recall that if the fuse blew the lights would be on permenantly, worth checking as it only costs you 5 minutes
    I had exactly the same thing about 2 weeks ago. The brake lights were stuck on and actually ran the battery down over night, thus i had to phone the RAC. They couldn'nt find a fault with the brake pedal switch and couln'nt help any further, so i took i down to local vx and left it with them.
    The result was that it was a faulty ecu for the rear lights. The box was replaced and so far has worked fine.
    Hope this helps, if you have'nt already sorted the problem.
    Cornwall
    Jolly, my local VX dealer said it was the fusebox needed replacing £235. How much did yours cost to fix. cheers.
    Jul 2006
    Mexico
    Quote Originally Posted by Mowster View Post
    Ouch! That´s an expensive fuse box! Did the VX people told you what exactly was wrong with it?
    The only wrong thing that I can imagine in a fuse box is that the electrical connection prior the fuses are loose...maybe it´s just a matter of re soldering that bad electrical connections or something.....unless its some sort of sealed unit or such.
  1. Check brake light switch = no turbo?!?! HELP!!
    By se4 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2012, 21:21
  2. Check brake light switch
    By dolf.peeters in forum Engine & Drivetrain
    Last Post: 5th July 2011, 00:55
  3. brake light removal help
    By Ben_ in forum Styling
    Last Post: 2nd June 2009, 10:07
  4. 3rd brake light removal.?
    By Dose in forum Bodywork & Interior
    Last Post: 2nd September 2008, 01:59
  5. 3rd Brake Light Removal
    By Baz07 in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 22:36
https:www.vectra-c.comforumshowthread.php30812-Brake-Light-Switch-Removal
changing brake switch in Vauxhall vectra 1.8
vauxhall vectra C stop-light switch
fitting brake light switch to vauxhall vectra
how to take out brake light switch on a 2008 tigra
how to take off brake pedal switch on 03 vectra
changed brale light switch on vectra c brale lights still on
signum remove stop light
change break lamp switch vectra c
where is.breaklamp switch on vectra c
how to remove brake switch on opel meriva
brake lights stay on vectra
how do i remove the brake light switch from a zafira b
zafira b taken brake switch off lights still on
brake light switch opel vectra c cena
How to remove stop light switch Vauxhall Vectra
changing vauxhall vectra 2008 brake pedal sensor
how to fit corsa c brake light switch
brake switch corsa c video
i cant remove brake light switch opel
where is the brake switch fixed in opel vectra
2008 vectra removal brake light switch
how to remove brake light switch vectra c
replacing brake light switch vectra 06
vauxhall vectra c how to fit a brake switch
