Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Poor Headlights
    Aug 2007
    Essex
    Default Poor Headlights
    Hi, this is my first post so please be gentle with me.
    I have just bought an 04 Signum Elegance and love the car to bits. One problem I have found though is the headlights are so dim on dipped beam. Is this a common problem with the Signum? I also have an astra that doesn't have this problem so I am wondering if the Signum uses inferior bulbs.
    I am very keen to sort this problem as I feel they are dangerous as they are now.
    Jul 2006
    Mexico
    Nope I think it´s a poor desing of the headlight unit itself....same on the Vecs BTW
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    there are various threads on bulb replacement and even a group buy on HIDS. Conduct a search and you will find plenty of idea's.
    there that wasn't so bad was it..............
    Aug 2007
    Essex
    Thanks for your replys. I have seen the threads on here about brighter bulbs but none of them actually said they had a problem. I had already half decided to get the Philips X-treme bulbs but just needed the extra push to do it. The only thing putting me off is the thought of fitting them. I think I will try Halfords for a supply and fit.
    Jul 2006
    Mexico
    Quote Originally Posted by maarten View Post
    The fitting itīs easy mate....itīs a DIY thing IMO....
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Hi, go here as Halfords do not do them.
    http://www.autolamps-online.com/prod...remecentre.htm
    Got mine and it was a quick delivery, plus u get 10% next order.
    Price is for a pair.
    Aug 2007
    Essex
    I have changed bulbs on other cars before and got on ok (maybe a scraped knuckle here and there). I think I would be ok doing it but I was also going to ask for the alignment to be checked as it does seem that they are very low. Even high beam seems to make a spot on the road instead of being spread out evenly. Is there a way to check the alignment myself and raise the lights slighty?
    Aug 2007
    Essex
    Thanks for the reply Merikiito. Is it the H4 or the H7 that I need for the Signum? I am fairly new to doing anything on cars and usually send it to the garage.
    Jul 2006
    Mexico
    Yeah the scraped knuckle itīs a must when changing the bulbs in this things
    I think you can play with the alignment with the two sets of white hexagonal heads on each lamp.
    Jun 2007
    in a white box
  1. A kind of fix for the poor pre-facelift headlights
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2015, 12:14
  2. Poor headlights on 2002 Veccy
    By Paul from Derby in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2013, 19:02
  3. poor headlights
    By phil sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2011, 10:56
  4. are veccy headlights poor!!!!
    By tommoturbo in forum General Chat
    Last Post: 25th February 2007, 02:43
  5. My Poor Poor Signum
    By Brake buster in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2005, 15:45
