Results 1 to 10 of 20
Thread: MOT time
    Jan 2006
    Skynet HQ EMEC#5
    Default MOT time
    My car's had it's 2nd MOT today, went through ok at the local Vauxhall dealer.
    Strange that it makes you nervous waiting to hear the outcome
    Only a couple of advisory items, nothing serious:
    slight play in both drag links
    slight wear in upper rear suspension arm
    Priced them up, not as bad as I thought, drag links are about £17 each
    Rear arm is about £65 complete with bushes in
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    what mileage is the cam chain/belt due change on a 2.2 dti
    ive done 55777 miles at the mo and due a service in march.
    well done on the mot, least you have a year to sort out the minor things.
    a bit of a seperate question really.. but the DTi timing chain is only really up for changing if it starts to make noise..a quiet running chain is fine, there is no 'real' interval on them..
    Ian,
    Nice result.. but it was a testament on how you look after your car....well maintained cars needent fear an mot..
    Well done Ian the drop links and rear arm can be bought a lot cheaper than that just have a look on e-bay for the bit's you need !!!!!
    Indeed - mine sailed through it's second MOT in June/July too.
    Central Scotland
    Forget about the timing chain unless it starts to rattle.
    I have just had my second MOT as well and the rear arms also have slight play in them. Passed with an advisory. Apparently this is a common fault with the vectra.
    Ian
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    mine went thru it's second M.O.T on Monday morning poifecty fine
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Good result.
    Nicking Ya Dinner.
    Rear arms are a weak point Ian, I had them replaced annually on mine, I wonder if you leave them they don't get any worse for a long time, like they settle in and it allows a bit of movement but don't get worse, be interesting to see next yr if you don't replace them yet.
  1. For once in a long time both cars are clean at the same time!!!
    By ijk571 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 10:40
  2. Long Time Looker, First Time Poster......
    By Whisky in forum Introduce yourself.
    Last Post: 26th March 2011, 22:37
  3. Long time looker first time poster
    By robg8070 in forum Introduce yourself.
    Last Post: 6th December 2009, 11:51
  4. long time user saying hello for first time!
    By Karnah in forum Introduce yourself.
    Last Post: 10th August 2008, 22:07
  5. Long time lurker, First time poster!
    By Crumpster in forum Introduce yourself.
    Last Post: 22nd October 2006, 07:47
