Results 1 to 10 of 16
Thread: Soundproofing the road noise
    Full Member
    Mar 2007
    Finland
    Default Soundproofing the road noise
    I'm planning to soundproof my vectra from the tyre and road noise. I've already ordered self adhesive damping material called 'Vibroplast' (http://www.standartplast.lv/index.php?navig=120).
    It is supposed to have good value for money, and it is successfully used by some car-hifi-chaps (pics of one project: http://www.kalliojarvi.net/ibiza/vai...mennus-2-e.htm)
    I will first do the trunk and the rear arches.
    I have never removed the inner paneling, so I'd need advice how to safely remove it in order to install the damping material to the bare metal, full lenght of arches and trunk?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What road noise ???
    Mine is very quiet. I don't think it needs any additional sound proofing.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I've done a fair bit of soundproofing myself & it didn't make a huge amount of diffence. The rear wheel arches aren't particularly easy to do either - I just took the boot floor mat out, removed the obvious clips on the side panels & it all came out fairly easily
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    quiet here also
    Jun 2007
    Cheshire
    Loads of road noise from mine - 1.9 CDTi design bought new in June this year. Particularly from the o/s rear.
    I believe others put it down to the Bridgestone tyres.
    Not a car that could be described as a relaxing motorway cruiser by any stretch of the imagination.
    Mar 2007
    Southport
    If you put the back seats down it's like driving a washing machine & as I doubt the rear parcel shelf is a particularly good sound absorbing medium I reckon you could do accomplish a fair bit doing something about that.
    Even after soundproofing there is alot of noise with the back seats down
    morton
    always had SRI models ! but peeps always comment on how they can hold a conversation (even at illegal speeds) without raising voices ! if anything i'd say mines too quiet !!
    Full Member
    Mar 2007
    Finland
    Thanks for comments. I've heard that the Dynamat/Vibroplast etc. mat should be molded directly to the metal surface. It should absorb low frequencies and vibration, for higher frequencies thicker felt or foam material should be used on top of the Vibroplast.
    Ian S100: What materials you used?
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by Big_Steve View Post
    The Bridgestone's do seem to be very noisy tyres ... I wont miss them when I change them. Mine can be quite noisy from the rear (with the Bridgestone's on) but I had a saloon before my current Hatchback and it was super quiet, particularly with the OEM Goodyear Eagle NCT5's on.
    Full Member
    Mar 2007
    Finland
    I have the OEM NCT5's on, 215/50/17, and they are quite noisy. The asphalt here in FIN might also play a role in this game...
  1. Road Noise
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2012, 23:45
  2. Road Noise
    By Andyjarvis in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2012, 16:53
  3. road noise
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2011, 11:12
  4. Road Noise
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 23:11
  5. Road Noise
    By Raze in forum Vectra C / Signum Troubleshooting
    Last Post: 27th October 2007, 12:57
