Results 1 to 10 of 11
Thread: sri dualfuel not starting !!
    manchester
    Default sri dualfuel not starting !!
    hello every1, just registered, looks like a mint site.
    Basicly i don't know if the dealers r fobin me off but my car died on me and has not started since, it cranks but just wont start.i am not getting a spark at the coil pack (which iv replaced). they did a tech 2 and it brought up some codes ( p0100 mass air flow ??-p0340 cam pos sensor-po335 crankshaft pos sensor-p1110 intake manifold solenoid valve 1 ) thay say they have tested all sensors and are all ok, tried both keys,fuel is present and pump works and i think codes may just flag up because it isnt starting and leaving open circuits??.the ignition ecu seems to be the next thing to be looked at as this is the only thing left and the most likely cause as diagnosed by another garage but vx say they cant touch it because they need to disconnect the gas to go further and are not trained to do so?? is this true ?? any 1 heard of this or have any clues and if it is the ignition ecu how much are they.
    Any help would be greatly appreciated, thanx
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Welcome to the site mate, Sorry cant help with your prob, but someone will be along with a few ideas.
    There are some tech guys on here who are a whizz with advice...
    Good Luck
    manchester
    thanks pal
    Tyneside
    I think there fobbing you off m8, keep at them till you get answers and get it sorted VX are known for their idle attitude.
    And welcome to the site aswell m8.
    EDIT: My englich is up my ar$e, see what I meen.
    Here, there and every where!
    Oops! I don't think you meant to call Vx "idols" did you m8 They are far from it.
    manchester
    thanks mate
    yeah sounds like it dunt it, i think im gona have to bite the bullet n take it to the vx approved lpg garage, i rang em n they said that the other vx dealer was fobbing me off, the guy said if i took it there then he has no doubt they could sort it but its getin it ther, its over 20 miles away!! n iv already spent £300
    lol@ Mark
    az sri, the dealers are very hit and miss m8, some are very good, others couldn't tell you if you had a flat tyre on a pram
    Try Pentagon in Oldham as you are in Manchester. AJA (member on here) has always had decent service from them, seem to know their stuff. PM him and ask his opinion m8
    Tyneside
    Quote Originally Posted by Caterman View Post
    lol@ Mark
    Now you've just hurt my feelings
    manchester
    cheers mate, do you know if they are lpg approved-thats the prob if there not they can only go so far with the diagnostic that i require - they need to disconnect the gas to test the ignition ecu apparantly which they are saying they cannot do due to not being approved?
    Don't know m8, try PM'ing AJA or give them a ring. If they don't they should know an approved dealer around that area for you
  1. 1.8 Dualfuel Starting Problem - LPG
    By Gaza999 in forum North East RO Vacant - ARO - Vacant
    Last Post: 17th June 2012, 17:33
  2. Problems with a 1.8 Dualfuel
    By Kyser143 in forum Engine & Drivetrain
    Last Post: 1st May 2009, 22:30
  3. Vectra Dualfuel
    By jamesr in forum Cars for sale
    Last Post: 23rd October 2007, 16:23
  4. sri dualfuel not starting !!
    By az sri in forum Engine & Drivetrain
    Last Post: 19th September 2007, 20:20
  5. Vectra Dualfuel
    Last Post: 30th May 2007, 21:28
