Thread: What does the "air quality" setting on the climate do
    Regular Member muffking's Avatar
    Default What does the "air quality" setting on the climate do
    Not a mod, but to save cloging up the general section, what does the Air Quality setting the Vectra's climate control actually do?
    If the air quality sensor (situated in the engine bay) detects harmful fumes (I'm assuming exhaust gases if you're sat in traffic) then it automatically switches to recirculation mode.
    Can't say I've ever noticed mine switch, even when I've had a load of fumes come through the vents into the cabin - I've had to switch to recirc manually.
    Oct 2006
    Wellingborough
    supposed to auto recirculate if it detects high pollution levels in the incoming air. never seen it happen and i follow a smelly tractor to work most days.
    Makes sense.
    I've never had it turned on with not knowing what it does, but why would you want to turn it off it turning it on is a good thing?
    Quote Originally Posted by muffking View Post
    ...but why would you want to turn it off it turning it on is a good thing?
    Think I got your gist there!! You mean why would you want to turn it off? You wouldn't really - best left turned on, not that it seems to work though! lol
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Works fine, but you'll notice that if there is a failure
    some time ago I had a problem with the servo motor... I could here it clicking every time it opened or closed. In city traffic, traffic jams or in tunnels this happened every few minutes. It is activated even if you drive backwards with a cold engine.
    Because of the ennoying noise I disabled the setting but then I could smell exhaust gasses in the car.
    (by the way, the part was replaced under warranty; only a 15 min. job)
    So when it activates the auto-recirc, is there any visual indication? i.e. is the recirc button meant to light up? (mine never has). Basically how do you know it's actually operating properly? Can you hear a servo kick in for example?
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    No there is no visual indication and like you, I had my doubts if it really worked. But as said, I saw (=heared) the difference when there was a problem with the valve. Once the problem was solved, I could not see any sign that indicates that it is working.
    What I do know is that the air recirculation position makes more noise than normal air flow (on mine anyway). So if auto-recirc kicks in when the fan is turning at higher speeds, you probably could notice it.
    Guess i'd better start using t then
    SOMERSET
    I have it and never noticed any difference in it at all
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  3. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  4. end of year bash 2008 "" will there be one ""
    By chrisgettings in forum General Chat
    Last Post: 3rd September 2008, 10:26
  5. CD70 Tel Mute also "mutes" the Climate Control
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2008, 09:39
opel vectra c air quality sensor
where is the air quality sensor on vectra c
air quality sensor vectra
vectra c air recirculation mode
