Thread: Shield under engine on a petrol?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Shield under engine on a petrol?
    Hi all,
    my better halfs vectra diesel estate has a large black plastic shield underneath the engine. So big you canot see the road if you look through the engine bay.
    My petrol 1.8 sxi vectra has what may be a bit of one left on the underside at the front ( its a long story why there may not be one there if there i meant to be!). So the question is do Petrol Vectras 1.8sxi have this shield or not? and if not can I fit one as strangley enough a friend of mine has one for sale (which I hope he hasnt taken from mine)
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    I believe most new cars have this skid pan.
    Its to protect the underside from catching on speed bumps. The downside is that they hide any damage as well.
    I would imagine that they are universal fit. Since he is a mate, fit it first then buy it.........
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Mines a 2002 Vectra C which is one of the first ones made I think. will need to look underneath I suppose and see if there are holes already made to screw the skid pan to (knew there was a technical name for a large bit of black plastic )
    I believe it's only fitted to diesels to help reduce the noise on the drive-by sounds tests as part of the regs. Stops some of the noise 'escaping' from the bottom of the engine bay out.
    Jan 2006
    Skynet HQ EMEC#5
    Don't worry, my 1.8 sxi is the same - only the one at the side
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Cheers for that Ian T , going to have a look to see if I can fit it anyway, I suppose just for the fun of it and its another mod
    Oct 2006
    Wellingborough
    If you do fit it let as all know how affects noise inside the car!
    Don't think it will TBH. As above I'm sure it's to dampen noise you hear at the roadside for the drive-by noise tests.
  1. Problems with 2,2 petrol engine
    By zafira in forum General Motoring Chat
    Last Post: 25th December 2012, 00:14
  2. petrol in a diesel engine!!
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 09:34
  3. 1.8 petrol engine, egr?
    By johnsav in forum Engine & Drivetrain
    Last Post: 6th August 2009, 19:08
  4. What is the best petrol engine?
    By jimmytwobikes in forum Engine & Drivetrain
    Last Post: 24th February 2009, 20:16
  5. Picture of a 1.8 Petrol engine
    By knoxy in forum Petrol Engine related
    Last Post: 17th July 2007, 16:32
