Thread: Tuning Box and DPFs
    Aug 2007
    Bath
    confused Tuning Box and DPFs
    I have tried a number of times to get my Tuning Box to work on my Siggy 1.9 120 (04 plate & 75,000 miles) but keep running into the old Spanner light issue after about 250 - 300 miles.
    The light will come on, you flick the ignition and it goes out for a few miles and then comes back on again. This will happen 10 - 20 times and then everything is ok for another 300 miles
    I have read a lot of threads on this site about issues with the DPF and tuning boxes. While I haven't mentioned the TB the dealer thinks that it might be the DPF failing to clear itself and then going back into drive mode.
    They want me to bring it in so they can take a look but there doesn't seem much point if it is just going to keep doing it.
    My question is - Is there a way to remove the DPF or at least get the system to ignore it? Or is there a way to force the DPF to re-gen?
    I have had the recall done but still get the problem.
    the only real way forward for you is to remove the TB in favour of a remap..the DPF is not something you can just whip out.. as the DPF is already struggling with the TB i'd get it off as soon as i could...
    The DPF rework should have come with a software update to make it regenerate more often anyway..so if the TB is still causing problems it'll have to go.
    Regular Member archerz's Avatar
    May 2007
    Teesside
    Engine : 3.0 v6 CDTI
    Mileage : 57500
    don't know if my 'caterman' box was any different but i had it on for hundreds of miles with no errors. (i have 56 estate) driven over 4k miles and nothing. how often does the DPF go off?
    did you ask for a box for your DPF car?.. if you did, it will have different settings which won't upset the DPF so much..
    Aug 2007
    Bath
    Thanks for the responses!!
    Have spoken to the guys at Dragon today.
    Their initial response was 'Why not take the DPF off?'
    Explained that it was required (and the ECU would almost certainly know that it had gone missing) so they have asked me to send the box back (again) and they will look at it's profile and make some changes.
    Will stick it in the post and see what happens.
    Knowing my luck I just have an over sensitive DPF!! Will let you know what happens
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Don't dragon state that their tuning box works with DPS's!
    I was also looking into this as i have a 57plate estate, after doing research mainly with help from this forum i've ordered a regal IPF unit, it works with the DPF by altering the DPF burn off settings.
    http://www.regal-shop.co.uk/acatalog/The_EDS_IPF.html
    If they asked me to take the DPF off i think i'd be a bit wary and walk away, It may suggest that they haven't done their research or testing of their units properly..
    From Dragons Website:-
    Tuning also suitable for Diesel Particle Filter vehicles - DPF FAP etc
    A further advantage of the new add-on electronic control units with multi ignition-map technology is their compliance with vehicle emissions standards. Through enhanced burning in all areas of vehicle performance, the fuel is 100% efficiently used, with soot and smoke being things of the past. Because of this, unrestricted installation of the modules is also possible in vehicles with diesel particle filter engines.
    from their page here.
    http://www.dragonperformanceuk.com/s...at=1110&page=1
  1. DPFs + MOTs
    By Dane-10 in forum General Motoring Chat
    Last Post: 26th March 2012, 21:02
  2. Any unwanted dpfs or anyone know where to get 1 free
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 19th February 2011, 23:16
  3. tuning box or not to tuning box that is the question
    By dazzer t in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 21:47
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
