Results 1 to 10 of 14
Thread: CD70 Crashed
    Selby
    Default CD70 Crashed
    Whilst driving home from work today I got a call via my parrot bluetooth.
    Answered the phone and the CD70 displayed "External in".
    Then....... nothing.
    Display remained "external in" for the rest of the journey and I couldnt switch the unit off either with the button or with the ignition logic. Nor could I use the radio or CD Player.
    Left car with ignition off for twenty minutes but it still displayed "External In".
    I eventually took the fuse out (No 1) and the CD70 reset itself when the fuse was replaced. Anyone else had this problem?
    Regular Member chinky's Avatar
    midlands
    yep had the same (often!!!!!!!!) switch ur phone then off for a min then back on should solve also there is an option in the the cd70 display menu that you can check(x) when this happens
    Selby
    Tried switching phone on and off. Drove home with the phone off (20 mins) Didnt work. Nothing on CD70 menu worked either. The only way to reset it appears to have been to remove the power source.
    midlands
    hmm dunno ive found a box that if you check or uncheck it cant remember which then this solves it did you try disconnecting bluetooth
    Selby
    I disconnected the bluetooth. Also, once the ignition switched off the bluetooth unit switched off but the CD70 stayed on with the "External In" message. It just froze. I also got the Satnav working but no sound.
    Hopefully its resolved but I will be waiting everytime the phone rings for this to happen again!
    midlands
    i know a mate with the same problem though dont think it has lasted as long as yours has i have found some phones have caused ut to stay off for longer i think the system does have issues but dont know the answer as dissconnecting has normally fixed it for me though i know i shouldnt have to do this
    Selby
    Not sure what to get rid of, the phone.... or the Vectra!!!
    midlands
    well ive had 2 diff fones and 1 same issue so the vec has to go loll
    Feb 2006
    Dorset
    Its your phone kit playing up not the headunit , its holding it on mute unplug the parrot kit and it will work again.
    midlands
    its vx inbuilt b/t in the cd70
  1. Crashed My VXR....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 20:17
  2. Crashed!
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2011, 17:35
  3. just crashed the vec :(
    By Craig1985 in forum General Chat
    Last Post: 28th June 2009, 17:36
  4. Just crashed
    By ste w in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 22:45
  5. I crashed it! :-(
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2006, 21:10
