Results 1 to 10 of 13
Thread: 225 45 R17 on SRI CDTI 150/190 Chipped ?
    Mar 2007
    Sunderland
    Default 225 45 R17 on SRI CDTI 150/190 Chipped ?
    Hi
    Had a blow out on drivers rear this morning luckly wasnt going that fast so was ok ! I need 4 new tyres anyway so its not all bad. My question is can I put 215 45 R17 on it (has standard SRI wheels) the standard tyres are obviously 215 50 R17. Will it look right or will the car have to be lowered due to the increased gap from tyre to arch ?
    One other thing I have two 225 45 R17 brand new in my dads garage so I was thinking if these are ok I could but them on and just buy two more ? will these be two wide ?
    Please help as I need to replace them as I currently have that terrible tiny space saver on !
    They will be fine Tim, a natural replacement
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    if you change the profiling on the tyre there will be an error with the speedo, be it only slight.... so you will need to make sure you know how far it is out...
    width wise it should not be that bad, as i have 18`s with 225 tyres on..
    we used to run 225's on 17's.. made very small difference at all..
    i'd just get them fitted....
    http://www.kouki.co.uk/Utilities/tyresizer.asp
    try this site out.. put in original and then new tyre sizes to find if much difference
    http://www.etyres.co.uk/tyre-size-calculator.htm
    Mar 2007
    Sunderland
    Thanks for the response and thats a great site to play around with the tyre sizes ! thanks !
    So the 225 45 R17 i have will be ok ? and i just need to get 2 more !
    Not got lots of cash u see ! my little bambeano is sucking me dry lol
    Mar 2007
    Sunderland
    My brother has just informed me that the two 225 45 R17's are about 5 years old (still have good tread) but are remoulds anyway !
    Brothers ! y did he tell me they were ok to use then tell me there 5 year old remoulds ? think i will pass on them
    Will just go with 215 45 R17's all round !
    Tyneside
    Quote Originally Posted by Tim View Post
    You will be forking out a shed load more ££££ then m8, thats whey everyone switches to the 225's as the range is bigger and much cheaper.
    Edit: Just noticed you said 215 45, what makes you wan't to go for these or is it a typo.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I dont have my handbook in front of me but IIRC 224 45 are a Vx recommended alternative & the size I've just had fitted - you could come unstuck insurance wise if you use a non recommended size. I don't recall ever seeing 215 45 mentioned
    Mar 2007
    Sunderland
    Opps ! didnt realise a 215 45 are non standard newbe !
    so there cheaper if you go for 225 45 R17 !
    Thanks for keeping me right lol
  1. Chipped 120 CDTi owners....
    By Trick202 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2008, 12:04
  2. CHIPPED UK RE-MAP DAY 24/06/06 (not 56k)
    By Robbieben in forum 2006
    Last Post: 12th August 2006, 19:38
  3. Chipped Uk Re-map 24/6/06
    By PIMM in forum 2006
    Last Post: 26th June 2006, 14:37
  4. Chipped UK 24/6/06
    By Spikey© in forum 2006
    Last Post: 26th June 2006, 08:08
