Thread: rear speakers
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default rear speakers
    guys how do u get the back door cards off to change the speakers? i have done the front ones but cant get the back ones off. i have manual windows if that makes a differnece
    Regular Member breezephil's Avatar
    LONDON
    There is a How to Somewhere... all i know is when it comes to taking the Window winder Handles off you need to watch out for the Spring-clip that holds them on..... one of mine went twang past my ear and into oblivion
    Aug 2007
    Lisburn, N.Ireland
    how did u get it off tho just pull hard?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The clip is horseshoe shaped and goes between the winder and door card,you can buy a tool for a fiver to remove them or use a piece of cloth in the gap to pull the clip out,with the cloth you'll have to try different angles because it depends on what way the clip is facing.
    Aug 2007
    Lisburn, N.Ireland
    any idea what its called or would any car shop know what im on about?
    Jul 2006
    Mexico
    Quote Originally Posted by aerodynamic18 View Post
    I think they are called tension or pressure washers(at least on the Spanish English translation ) as Tyreman said they have a horseshoe shape and you have to find out its position so you can push them out....by the way be careful when you do it.... they suddenly pop out and fly and is easy to loose them.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Just ask in a car shop for a window winder removal tool,cheapest one will do.
    Regular Member david.aka.judas's Avatar
    Suffolk
    normally called and e-ring or a cir-clip.
    Suffolk
  1. Rear Speakers
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 18:50
  2. Rear speakers
    By Smudger34 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 12:17
  3. Rear Speakers
    By SRI-Diesel in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2010, 13:01
  4. Rear Speakers
    Last Post: 21st May 2009, 08:41
  5. no rear speakers?
    By Big Knox in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 13:03
