Results 1 to 10 of 26
Thread: Fitting electric rear windows
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Fitting electric rear windows
    Is it possible? Is it as easy as buying the motors and switches and the loom being in place already or is it more involved?
    [Ex]Admin Duncan's Avatar
    Basically somewhat more involved as IIRC the looms aren't in place on a car that didn't have them fitted as standard. There's a long thread on exactly this, which a couple of people have successfully done. Have a search and you should find it.
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    what does iirc stand for duncan?
    Jul 2006
    If I Remember Correctly
    Regular Member Damian's Avatar
    Market Drayton
    Am part way through doing mine, I got the looms and regulators and switches from a breakers off an elite I think.
    Have installed the door looms and the switches and had the "power" to the rear doors switched on via TECH2.
    I found the looms tough to install as I have big hands, I think little girly ones are definately an advantage.
    "All" I need to do now is drill out the old regs and rivet in the new electric one, and all being well, hey presto !!!!!
    I keep putting this bit off because I am a bit concerned about breaking the glass, so I am waiting till I have got a full weekend without my 3 year old around so I can give it maximum concentration.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Damian, did you ever get around to doing this?
    Market Drayton
    Funnily enough finished at the weeknd as the nipper was away.
    Apart from damaging a plastic clip which holds the glass to the regulator (Which hopefully will hold) it went pretty darn well.
    Having done the looms already and had the power switched on, each door took me about 2 hours and that was working very slowly and carefully.
    Never used a pop rivetter before ans it didn't half scare the poop out of me when it popped the rivet in.
    The old regs drilled out okay and fairly easily, and just made sure after releasing the glass frmo the reg clamp that it was well masking taped shut so it didn't fall down whilst drilling.
    The only bit I found difficult was getting the plastic clips back into the new reg and the glass, it's a very small space to work in and I have big hands and arms.
    Any issues hopefully I can assist in helping
    @home
    Engine : 1.9 CDTi
    mind me asking how much you paid all together for the parts, and do you have any part numbers?
    Market Drayton
    I think I paid about £100 for the looms and regs, and then another £35 for the rear switches and the front drivers switch. I then bought another drivers switch off here as it had the electric mirror logo on it which is my next task when I can raise the funds.
    Plus the £50 TECH2 activation as well
    The part numbers are
    Rear Regulator (Rear window regulator Right Hand Side - 24451522)
    Rear Regulator (Rear window regulator Left Hand Side - 24451521)
    Rear Wiring Loom (Rear Door Wiring Loom Right Hand Side - 13139952)
    Rear Wiring Loom (Rear Door Wiring Loom Left Hand Side - 13139950)
    Try Autobreakers - 01772 253368 or LVM Ltd - 020 8345 5148
    I do not have the part numbers for the switches but have the drivers switch for sale here
    I tell you something, it was a mistake buying an SRi and trying to turn it into a Design, must be a lot cheaper the other way round !!!!!!!
    @home
    Engine : 1.9 CDTi
    Did you take any pics while you were doing all this?
    Does the new loom just connect to the existing loom?
    I'm going to do the mirrors too, so will need a new DDM I had a part number for this but I guess that may need to change to include the rear window controls?
    Hope it will be worth all the work :-)
  1. stage one of fitting rear electric windows done today
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2011, 22:49
  2. fitting electric rear windows and tech2
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 04:12
  3. Electric rear windows fitting today
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 12:13
  4. Fitting rear electric windows
    By mathewjcooper in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2009, 23:09
