Thread: Cd40
    Regular Member Ali's Avatar
    Northern Ireland
    Default Cd40
    Does anyone know if you need to change the standard display to the graphic display when you change from CD30 to CD40mp3?
    I know that it needs Tech2'd.
    Thanks.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by Ali View Post
    Thanks.
    CDC40 is not MP3 it is a 6 disc multi-changer with DAB. The DAB unit is not within the confine of the unit, it is a seperate box. To change it over would need all new looms just for the radio then you have the looms to change for the Graphic display. Don't think it would work with the standard display otherwise penny-pinching Vx would do it.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Thanks.
    CD40mp3
    If you mean CD30MP3 you do not need to change the display;
    if you mean CDC40... yes, you need a GID or a CID
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by sig63 View Post
    I forgot there is also a TID, the one with the two buttons
    if you want to see the ID-tags, you'll need the BID (board info display, the one you will have if you have BC)
  1. cd40
    By jpbroad1970 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2012, 20:49
  2. Cd40
    By dustydes in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2011, 10:31
  3. CD40 help please
    By cossie in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2011, 21:20
  4. cd30 to cd40
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 16:09
  5. Cd40 dab says no :(
    By larrygroke in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2011, 13:08
