Results 1 to 10 of 22
Thread: ball joint type of clonk on suspension
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Default ball joint type of clonk on suspension
    today i heard for the first time a type of clonk knock just like a ball joint
    does but it sounds from the fronti ave had the car up in the air today and
    checked around the suspension but i cant find the problem so has anyone
    had this type of noise,i`m pretty sure its coming from the front,any info is
    much appreciated but i`ll be getting it into the dealer tomox to get it seen
    to.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi andy, did you check your drop links from the shock to the anti-rool bar they can make quite a bad knocking noise
    12 Post(s)
    Trim : elite
    Year : 2011
    i did have a quick shuffle around but didnt find anything obvious so i`ll get
    it into the dealers and let me m8 have a look at it.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    hope it isn't a big expensive job for you mate
    Midlands Mod Shop - NFFC.
    Andy i would put money on the "Drop links" matey the clonk wont show up much if you jack the car up as they are under load so will feel tight anyway the dealer can pay for them as they are only cheap !!!!!!
    i'll 2nd Drinky on this one....
    12 Post(s)
    Trim : elite
    Year : 2011
    cheers guys
    after that day i aint heard anymore clunking upto now but think i`ll get
    the drop links replaced anyway.seems strange it only done it just that 1
    day
    Regular Member tpj2007's Avatar
    Aug 2007
    lincolnshire skegness
    hi ive not long bought vec vxr and its got a creeking from n/s front when i turn right slightly but i cant see any thing at all is that the same as your noise or has any one else any clues
    Oct 2007
    west yorks
    Default clonk
    andy,
    i've had this problem for quite a while on my vectra sri 03. Its starting to do my head in, my local garage replaced a front wishbone ball joint which sorted the problem to begin with, but now its back worse than ever. This cost me £170 so im not too keen to get the other wheels done!
    I would be interested to hear if anyone else has had to get this done.
    that seems a steep way to do it.....
    they normally knock from the antiroll bar links, which are far cheaper..the lower arms don't really wear in my experience..
    they're not that hard to change, so if you do need the other side doing ( has the noise changed where it's coming from) then i'd contemplate doing it yourself..
  1. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  2. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
  3. Lower suspension ball joint
    By frenchman in forum Suspension, Wheels & Brakes
    Last Post: 21st October 2009, 19:59
  4. Ball Joint failure
    By peter142 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2008, 18:18
  5. Vec B REAR SUSPENSION CONTROL ARM BALL JOINT
    By deanos in forum Parts for sale
    Last Post: 3rd October 2007, 13:51
vectra c ball joint
vectra c checking a ball joint
vectra c bwll joint
