Results 1 to 10 of 14
Thread: Microfibre cloths
    essex
    Default Microfibre cloths
    Hi all, did a clean polish wax with meguiars yesterday. Nice results, but..... can't seem to get a good drying result with a microfibre cloth, it just seemed to move the water around, and smear it. Ended up digging out the chamois which worked perfectly. Am I missing something? Cheers.
    What sort of Microfibre were you using.... need a 'waffle' type towel like a Megs Water magnet. ALso, best results are gained by getting most of the water off first with a silicone 'blade' type squeegee.
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    As above, also I recommend when you have removed most of the watr, spritzing it with some Megs last touch, this elimnates any watermarks and leaves it nice and slick ready for what ever treatment you have in mind after.
    essex
    Just a 'normal' microfibre cloth, similar to the Meguiars supreme shine microfibre, no waffle !
    That will work, but will fill up with water very quickly... best to get a Water Magnet, and a silicone blade.... and as Marty says, use a bit of Last Touch or Quik Detailer while drying, to help lubricate the panel and remove water marks.
    Regular Member denzo's Avatar
    Runcorn
    Saw the microfobre cloths in Costco ... large packet of 24 for about £7.00
    They were the real ones ... just don't need 24 of them
    I could use 24 in one clean!!!!
    Mileage : 000
    Are you useing a micro fibre cloth that you polish the car with to acctually dry it, As you would be better off useing a micro fibre Drying Towel to dry your motor. There is a difference between the two types of cloth,s.
    essex
    Quote Originally Posted by denzo View Post
    That's the ones I'm using.
    No, I'm not drying with the polishing cloth
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Tip, Rinse your car with a watering can with the end taken off or open hose pipe (flooding method). The water will just sheet off leaving very little on the car, then just pull a waffle microfiber over the car and it will be dry. A good clean paint surface (clayed and waxed) will hardly need drying, just draging a cloth over the hole car in one go will do.
    Take a look here. HTH http://uk.youtube.com/watch?v=BZCi0_...elated&search=
  1. Tesco microfibre cloths
    By chris_sri in forum Detailing and Car Care Discussion
    Last Post: 28th May 2010, 21:37
  2. Microfibre cloths
    By KTM Chris in forum Detailing and Car Care Discussion
    Last Post: 26th September 2009, 12:59
  3. Microfibre cloths @ b&m stores
    By bloodworm in forum Detailing and Car Care Discussion
    Last Post: 9th May 2009, 17:46
  4. Microfibre Cloths
    By WeDesign in forum Detailing and Car Care Discussion
    Last Post: 8th March 2009, 11:06
  5. Microfibre Cloths
    Last Post: 19th June 2008, 14:00
