Thread: Engine misfire? when under load
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Default Engine misfire? when under load
    Hi my Vecta C 2.2 petrol Z22SE starts perfect and revs reasonably smooth, you can tell its not quite right though, a little rough.
    But the story soon chnages when I try to drive the vehicle, you can set off OK but when I put my foot down, it does speed up but very badly like its just not running on all cylinders correctly.
    I have read talk of the flywheel/clutch but there is no problem when parked and reving the engine, it doesnt rev perfectly smooth but there is certainly no vibrating or rumbling.
    It never lights the management light either.
    So far I have checked for faults at a non Vaux dealer and found none, it did find my airbag light though, so it should have worked OK.
    I have changed the spark plugs, tried a good coil pack and removed the EGR valve, blanked it off and put a cheater diode in its place and non of these have been the problem.
    Ideas please, as Im really stuck on this one, could it be a dodgy injector?
    Get someone to check out the Crank sensor for you sound's to me like something breaking down under load a good auto sparky should be able to sort you out HTH!!!!!
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    Quote Originally Posted by Drinky View Post
    Hi and thanks for the reply, funny enough I have the crankshaft sensor wrote down on my list, I just cannot understand why it never read a fault.
    bradford, west yorkshire
    hi symon i've replied to the message you sent me but you ned to clear some of your messages in your inbox to recieve the one i sent.
  1. Part load misfire 1.9CDTi 150
    By Python in forum Engine & Drivetrain
    Last Post: 12th November 2012, 17:40
  2. Signum 2.2 direct misfire under load
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 19:23
  3. 3.2 V6 Petrol GSi Misfire Under Load
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:22
  4. Misfire under load. 2003 1.8 DuelFuel.
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 8th April 2009, 23:22
  5. Replies: 3
    Last Post: 20th September 2007, 21:34
vauxhall vectra 1.9 cdti misfire under load
crank sensor breaking down under load
vauxhall vectra c 1.9 cdti misfire under load
vectra 2.2 direct vectra c crank sensor site:www.vectra-c.com
vectra c 2.2 petrol crank sensor site:www.vectra-c.com
