Thread: manifold
    Regular Member rob_gsi's Avatar
    May 2007
    Central Scotland
    Default manifold
    does anybody know how the inlet manifold comes off on a 3.2 gsi vec?
    Depends how far off you want to take it if you want to gain access to the plugs or coil packs then it is a case off remove the air inlet from the airbox then the black ECOTEC cover and there are 5 holes you will need a torx drive bit carn't remember the size undo these and it will lift away but remember all the pipes and wires are still attached there are no gaskets to worry about either HTH!!!!
    Don't forget about the bolt under the throttle body housing as well Chris.....6 'bolts' in total..very soft heads as well, so be careful and they will have corroded in as well, so they will be very tight...Be very careful and don't rush it..
    May 2007
    Central Scotland
    thanks for the help guys much appreciated
    Regular Member marcdale's Avatar
    May 2006
    Bristol
    Quote Originally Posted by Drinky View Post
    You'll need a long reach T30
  1. is it the manifold?
    Last Post: 15th June 2010, 16:09
  2. manifold help
    By Graeme01 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:20
  3. manifold help
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 31st January 2010, 22:20
  4. 2.4 manifold
    By lizard in forum Petrol Engine related
    Last Post: 15th November 2008, 22:00
  5. manifold will it??
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 21:28
