Thread: Removal of Ribed AUX belt
    Regular Member pauls898's Avatar
    Malvern
    Question Removal of Ribed AUX belt
    How easy is it to remove the Ribbed Aux drive belt from the 2.0L Turbo engine? The Sabb engine model, 25 xnet I think its called
    I am trying to diagnose this whinning noise which I think is getting louder, it only happens at start up and lasts for a few miles but has gone by the time I drive to the VX dealer, Typical lol.
    I am convinced it is coming from the tensioner pulley bearing, so to prove it once and for all I want to remove the belt and start the engine briefly, I know I won't get any charge to the battery or Air con won't work, but I want to check if this whining noise goes away with the belt off?
    Do I need any special tools to take off and replace this ribbed aux belt?
    Paul
    i wouldnt fancy taking it off myself.iam 90% sure thats your problem as mine was changed b4 i had it,due to that noise.if it was me ild make them have it over night so they could start it first thing in the morning.
    Malvern
    So did you have the tensoner puley replaced? Was that what the noise was caused by?
    i think it was just the belt maybe the pulley not sure but one was the cause
    Malvern
    Sorry to be a pain. Did it sound like a mini metro / old mini whining noise? which lasted about 5 minutes till it warmed up?
    I had my ribbed belt replaced at the service at my own expense but the noise is still there? Therefore I am convinced it must be the tensoner pulley bearing? But thats gona cost me about £60 to replace if its not that, as VX dealer won't change it at my request unless I pay first. There's nothing else as its not the alternator or Air con compressor as checked them with a pipe in ear trick and they are quite.
    Paul - I had a similar problem on mine. Got a 'chirping' noise when I started it from cold. Got the Multi-V tensioner replaced (and they replaced they belt at the same time) under warranty and it's been fine ever since.
    HTH
    scotland
    my pulley that the belt runs on sheared off completely yesterday10/12/2005 and it was making this noise!!! i bought a new one from reg vardy and they said a modification to this part was made as v/hall know about this supposidly.
  1. 2.0dti water pump/belt removal and refiting
    By gjsteed in forum Engine & Drivetrain
    Last Post: 16th August 2011, 19:43
  2. Rear Seat Belt Removal - Vectra C
    By tutfut01 in forum Bodywork & Interior
    Last Post: 16th September 2010, 10:28
  3. signum seat belt removal
    By lepip in forum Bodywork & Interior
    Last Post: 28th July 2008, 11:37
  4. Front seat belt removal
    By kel123 in forum Bodywork & Interior
    Last Post: 11th July 2007, 17:10
  5. Rear seat belt removal
    By monkeybusiness in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2006, 15:16
