Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Noisy tyres and juddering clutch solved.
    Regular Member videodoctor's Avatar
    Blackpool
    Default Noisy tyres and juddering clutch solved.
    Hi,After speaking with my dealer about the noisy tyres on my Vectra 1.8vvt they said i could buy brand new ones for the discounted price of £45 each fitted.This was for Dunlops.I initially agreed but asked to take out a similar car with different tyres to mine to listen to the noise.
    I went out in a 1.8 sri 07 plate and while the tyres where slightly quieter than mine,there wasn't that much difference.I'd say about 10% quieter.
    After this test drive it was quite a shock because i thought the other car would be whisper quiet.I wasn't prepared to pay £180 to have my tyres changed for the sake of 10% difference.
    I since have had the clutch replaced under warranty today(modified clutch from Vauxhall,lovely and smooth again instead of juddering up the street!) and they gave me a Corsa 07 plate car for the day.The noise in this car was even worse than the veccy and there was a constant droning sound from underneath.The tyres that were on this car where Goodyears so i have come to the conclusion that its not all the tyres fault more that its lack of sound proofing because all the cars i have driven with different tyres sound the same as mine.
    I have since put 2 layers of underfelt in the boot and that made a big difference.I then temporaryly fitted underlay felt under the bonnet card.This made a massive difference to the sound and have now been looking into buying a felt material that is fire proof.
    This is what i'm thinking of getting...
    http://www.woolies-trim.co.uk/c-126-felt.aspx
    So anyone else thinks that their tyres are noisy then unless you can get them for free i wouldn't bother with the expense.Sound deaden the car instead.
    yep, top tip here.. remove the boot side liners and soundproof the inner rear wheel arches.. that and the boot floor quieten the inside down quite a bit....
    morton
    my SRI is super quiet ! and so was the first one i had ! how strange that yours is'nt ?? glad you did'nt fork out for new tyres ! i'd be tempted to try a different set of alloys on your car just as a comparison !
    Regular Member the floyd's Avatar
    north east of england
    I to am having same problem with gear change between 1st and 2nd.seems to judder when trying to hold clutch to pull away in 1st gear.then it will suddenly jump forward giving me and the wife whiplash.my car is a 2006 1.8vvtsri.do you think its worth me getting it checked out by the dealer.
    Regular Member jammydodger's Avatar
    lancashire
    the boot soundproofing might explain why mines ok, cos its always full to the brim so no room for sound to travel at the back.
    Quote Originally Posted by the floyd View Post
    oh yes!!!, and ask them to fit the newly released 'upgrade' parts that eliminate clutch judder on the 1.8's...only released in the last few weeks, so they will know.. if they play dum, ask them to call VX tech Services and ask about the upgrade..
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    06 defo get it down the dealers. Seam to be quite a few 1.8's with this problem.
    As for sound deafening, try roofing felt, its just like dynomatt but a hell of a lot cheaper.
    thanx for help.will be ringing dealer tommorow.
    Blackpool
    Get you car down to the dealers asap.There are a few of my threads on here about the clutch judder.Print some of them off and take them with you.My dealer initially tried to fob me off and say that there was nothing wrong with the 1.8's.After showing him some of these threads he changed his mind and got onto Vauxhall,who very quickly came back with a case number.I had to wait for approx 2 months while they got stocks supplied but i kept on at them and today it's been changed.(Mine was the first one they had done).Anyway lovely and smooth now and the car seems more responsive and the gear change from 1st to second is better.
    They change the flywheel as well for some reason.
    The new clutch is out there now so don't be fobbed off
    Quote Originally Posted by videodoctor View Post
    if the clutch has worn the flywheel surface 'oddly' then the new unit will still judder.... so they swap the entire unit..
  1. Noisy clutch question
    By goooba769 in forum Engine & Drivetrain
    Last Post: 9th July 2012, 10:27
  2. noisy clutch
    By tazdog03 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th June 2012, 21:08
  3. New clutch now juddering
    By Angelchops in forum Engine & Drivetrain
    Last Post: 19th August 2011, 22:11
  4. 1.9CDTI Clutch Juddering
    By robdd1 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 21:00
  5. Juddering Clutch Saga.....
    By sonic in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 22:27
vectra c sri clutch judder when hot
