Thread: Lowering the Signum
    Regular Member dazza1964's Avatar
    Leeds
    Default Lowering the Signum
    Hi all, will be looking at lowering the Siggy soon.
    Just wanting opinions as to the best set up and how far to lower.
    30/40 mm?
    Bilsteins / Spax / konis?
    Which springs?
    Wanting to spend appx £350
    Also, is it worth poly bushing?
    Strut brace?
    Jul 2006
    How far to lower is entirely up to your personal taste.....
    You don't necessarily need to change the dampers, the standard ones are up to the job if you're only going down to -30mm.
    Bilstein have been used by several members on here with no problems, but the Koni FSD's are apparently superb. If you're changing the dampers you may as well do the bushes while they're off although i'm not sure if you'd notice any real difference if you did it all the same time.
    Strut brace - yep, the people who have them reckon they really help the car's handling.
    I've got Eibach springs with the standard SRi shocks, and although you can hardly see the difference in height (from -20mm to -30mm), the ride and handling are soooo much better.
    I'd say go for Eibach springs and a strut brace, and leave the dampers for now.
    >>>>>Waiting to be shot down in flames.....
    Regular Member j13hdb's Avatar
    Nottingham
    Does anyone know where you can get a strut brace for less than the £140 that Regal are wanting please (fo a 3.2)
    Jul 2006
    The one Regal sell is made by Lexmaul, i'm not sure who else makes them to fit the Vec C.
    i think the only option is the Regal one....
  1. Lowering My Signum and Induction Kit
    By chrissy white85 in forum Handling & Braking
    Last Post: 19th October 2012, 19:11
  2. Lowering A Signum 2.8T
    By PORKBALLS29 in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2011, 14:59
  3. Lowering my Signum V6
    By r1riderx in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2008, 17:38
  4. Signum lowering
    By andy13 in forum Handling & Braking
    Last Post: 15th March 2008, 14:00
