Results 1 to 10 of 14
Thread: Air Con On - Power Gone
    Doncaster
    Default Air Con On - Power Gone
    Don't know if I've posted this on here before, if so, sorry in advance
    Got a 1.9CDTI 150BHP.
    When I have the air con on and try to pull away in 1st - most often than not I've got little power available. It goes like a snail for a second or two, and then picks up - great on roundabouts
    Is it that I'm just not putting my foot down enough, is it normal, or not!!!
    thanks
    Richard
    Regular Member R-man's Avatar
    Beds
    Well for a start you'll always have some turbo lag, and air con sucking the life out of your engine will only make it worse. I would say its normal, and although many would disagree when I was in a CDTi I just used to ride the clutch a bit for a quicker set off at roundabouts etc.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    When i have the a/c on in my 2.2 petrol i need to give it a little more gas when pulling away. So IMO it is normal.
    [Ex]Admin Duncan's Avatar
    The 1.9CDTi does seem to suffer from bad turbo lag, so the air-con taking a little bit of power away additionally wouldn't help.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Can't say I've noticed any such problem with my 2.0T petrol.
    No me neither (forgot to say).
    Beds
    My 1.8 is awful. Its ok if the air con is on low, but if you have it on full wack it just hates moving, if i take my foot off the accelerator you slow right down. TBH even the braking seems to be affected when its on full go, cant think how that makes sense.
    Roll on next May time
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by R-man View Post
    My 1.8 is awful. Its ok if the air con is on low, but if you have it on full wack it just hates moving, if i take my foot off the accelerator you slow right down. TBH even the braking seems to be affected when its on full go, cant think how that makes sence.
    1.9 CDTI = Lotsa torque, loadsa lag.
    2.0T = Lotsa torque, no lag.
    I had a 1.8 before and would agree. Momentum builds up much more quickly in the 2.0T, and is maintained for longer if you take your foot off the accelerator. In addition full torque is from 2500 rpm which is almost diesel territory. Best of both worlds....even if it does burn more fuel.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    The 3.2 doesn't seem to suffer either
    Feb 2006
    Guttedsville
    Mine is a pig trying to pull away with the Aircon on. Plenty of revs and a slight slip of the clutch seems to be the tecnique. Wonder if a remap would improve matters?
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
