Thread: Sick Signum 2.2 Direct (Fault Codes)
    Jun 2007
    confused Sick Signum 2.2 Direct (Fault Codes)
    Hi Everyone. I hope someone out there can give me a bit of decent advice re my sick Signum. I'll try to make a long story as short as poss. The car has had loads of problems over the last few months starting with poor cold starting, then engine going into limp mode intermittently. I had it into the local stealers who diagnosed a faulty high pressure fuel pump and pressure regulator. Before I had that fixed, the water pump went which cost me just under £1500.00 to get replaced (the job grew after they had got it into their workshop). When I got the car back, the previous faults had disappeared even though they did not replace the pump or regulator although the cold starting was still a problem. A short while later, it developed a constant problem where it goes into limp mode. Everytime I take it to the stealers, they want to charge me for "diagnostic checks" which never seem to diagnose the problem and they just keep wanting to replace parts until the problem is solved. I have now got myself a code reader and the main codes that keep appearing are P0301 (cylinder 1 misfire) this is the one that seems to cause the limp mode and comes up all the time. P0303 happens occasionally and the one that is baffling me is P1666 which now comes up quite regularly. I cannot find any info to what Vauxhalls definition of this code is. Various "knowledgable" people have informed me that the coil pack needs changing, the ect sensor needs changing and a list of other parts that it too long to go into. I don't mind changing parts if they are faulty, but at this rate I'm going to be bankrupt changing parts that do not cure the problems before I have a car that is driveable. Any help would be greatly appreciated. Here's hoping.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected
    Jun 2007
    Thanks for that, but is P0166 the same as P1666? If so, Where is the sensor and is there a way of testing it?
    I really do need to get up to date with the mechanics of modern cars.
    Thanks again
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by kaston View Post
    Thanks again
    List of codes in this
    Unfortunately I only know where the engine is. Surely someone will tell you where your sensor is. It may be in front of the engine block IIRC from a previous thread on here.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Isn't a oxygen sensor in the exhaust?,try looking on the manifold or downpipe.I think testing it is beyond a home mechanic and substitution is the answer.
  1. my poor 3.0 sick again..my fault no doubt
    By Guss in forum Y & Z30DT Specific
    Last Post: 2nd June 2012, 15:12
  2. 2.2 direct petrol 05. Fault codes
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 15:35
  3. Replies: 6
    Last Post: 26th March 2012, 16:42
  4. 2006 Signum 2.2 engine fault codes! Help please :)
    By t13con in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:39
  5. Signum 2.0 dti fault codes
    By Babycake in forum Engine & Drivetrain
    Last Post: 7th April 2010, 11:25
