Thread: upgraded brakes
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default upgraded brakes
    i am lookin at the 320mm brake upgrade kit from lmf and it says that min wheel size is 16inch i have a sri wit 17 nch wheels but what about the spac saver will that work ok? also is is an easy or hard to do. was everything included like the shield for behind the disk. was thinkin about doin this before i remap the car.
    Regular Member wardy's Avatar
    Chichester
    Ive got the V6CDTi with standard 17 SRi wheels and the big brakes are standard on that. Although I've never tried it (touch wood) I have a spacesaver so it must be OK.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    buy a cheap 17" sri alloy as a spare...........problem solved
    Midlands Mod Shop - NFFC.
    Chichester
    there isn't a problem.
    The space saver is standard issue on my car, as are the large brakes.
    Aug 2007
    Lisburn, N.Ireland
    i guess that the fact it is a kit i wont need anything else ie the cover for the back of the brake disks? is it hard to do? i am thinkin im going to do this asap as about to remap car so want the stoppin power sorted
    Jul 2006
    Yes, they're fine behind the space saver, and you don't need new dust guards, the discs fit - just - behind the originals.
    unless you have the estate or signum, junk the spacesaver, it's just bad news..
    and yes, the brake upgrade is easy to fit.. you will find that the dust sheild is a bit smaller than you expect as it really only protects the lower balljoint, the rest is left out to air..if you have any real trouble, just post up and we'll guide you through it..
    Aug 2007
    Lisburn, N.Ireland
    would another standard wheel fit in the wheel well?. the only bit im worried about is changin the calipers and rebleadin the system as i have changed disks and pads before. ay tips on this bit?
    Quote Originally Posted by aerodynamic18 View Post
    remove the black plastic spacer ring in the bootwell and yes, a standard wheel will fit into a hatch or a saloon..
    tips?..do one side at a time and use hose clamps to minimise fluid loss..replace the washers either side of the banjo hose connection and don't overtighten the banjo bolt..then just use an 'easybleed' ( avaliable from halfords for around a tenner) and pressure bleed the air out..just make sure when you assemble the caliper to the hose you put it on the correct side with the bleed nipple upperwards ( eh Plasma..)..
  1. VXR upgraded
    By bembo449 in forum Insignia car chat
    Last Post: 3rd December 2011, 19:45
  2. upgraded to 314mm brakes, now no pressure.
    By Mark_k in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2011, 21:42
  3. upgraded
    By tonyv6elite in forum General Chat
    Last Post: 9th April 2009, 17:55
  4. Upgraded Brakes
    By sycho666 in forum Handling & Braking
    Last Post: 4th September 2008, 19:19
  5. Upgraded rear brakes
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 19:26
