Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: Spoons FMIC Front Mounted InterCooler
    spoons
    Guest
    Default Spoons FMIC Front Mounted InterCooler
    Hi All,
    How to fit a Front Mounted InterCooler to a Facelifted Vectra 1.9 CDTi SRi Nav
    Following on from this thread I decided to give you a summary of what I finally did.
    First I bought a Front Mounted InterCooler off eBay (Search for item - 220144653681)
    The Dimentions of the intercooler are as follows...
    - 2.5" inlet/outlet
    - Core Length : 21"
    - Core Height: 6"
    - Core Thickness: 2.5"
    - End to End" Length: 28"
    In the advert it states that the core thickness is 2 3/4" but its not... its actually 2.5" (which is in our favour). Also it states that the end to end length is 28.5" but its not.. its 28" (which again is in our favour).
    Secondly, as the new FMIC would be blocking the radiator at the bottom, I decided to cut out the blanking plate behind the grill to allow more air through...
    Then comes the fitting...
    The mounting holes in the top of this FMIC are 8mm in diameter and I purchased some 8mm rods which simply screwed into the holes. I then got some 'L' brackets and used a 6mm bolt through the crash bar to mount the 'L' bracket to the bar itself. Then I attached the 8mm rod through the 'L' bracket and cut it to size. Then fitted it all with 8mm bolts which also have nylon inserts to stop them undoing.
    The intercooler is as far back as it can possibly go without touching the heat exchanger behind. You will need as much space for the bumper to fit, so as you can see above, its really tight, but fits perfectly.
    HOSES
    Ok... On the passenger side you will need the following
    1 x Samco Xtreme 90 Degree 63mm to 57mm Reducer Silicon Hose
    1 x 60-80mm Stainless Hose Clip
    1 x 50-70mm Stainless Hose Clip
    1 x 2:1/4" Alloy Hose Joiner
    1 x Samco 90 Degree 57mm Hose Elbow
    2 x 50-70mm Stainless Hose Clips
    On the drivers side you will need
    1 x Samco 90 Degree 63mm to 51mm Reducer Silicon Hose
    1 x 60-80mm Stainless Steel Hose Clip
    1 x 2" Diameter - 3 Inch long Alloy Joiner Hose
    1 x Samco 90 Degree 51mm to 45mm Reducer Silicon Hose
    3 x 40-60mm Stainless Steel Hose Clips
    Getting the bumper back on in one piece is almost impossible, so I had to make some alterations to the bottom grill.
    Firstly you will need to cut off all the nobbles
    and ensure that the 'Air Flow Meter' is relocated. I stuck it up in the top right hand side of the grill...
    BUT, it does all go back on so enjoy !!
    Ex-Staff Full Member Mark The Cabby's Avatar
    Feb 2006
    In a house
    Vehicle : Ford Mustang
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Steve,
    That's a super looking job there mate, You will have to let us know how it makes a difference after a drive or two.
    It's Mustang time...
    Well done Steve super write up !!!
    spoons
    Guest
    Quote Originally Posted by Mark The Cabby View Post
    Quote Originally Posted by Drinky View Post
    Thank you. I did go through some mental and physical pain with this project. But it looks a good result.
    Final finished picture...
    Regular Member wardy's Avatar
    Chichester
    Humm,
    Would this work on a V6CDTi??
    Tyneside
    Looks great m8, credit to your hard work and perciverance
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    excellent write up. just need to see the benefit on the rolling road now..
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Good write up there steve, but Air Flow Meter, thought that only one was a MAF? up by the airbox
    Feb 2006
    Guttedsville
    Brilliant. Superbly done. Nice and discreet too, just the way I like it. Given me far too many ideas for 'Stealth Signum'.
    And I wasn't modifying it!!!
    Mileage : 000
    Nice write up Steve, it must heve taken you as long to take the photo,s as it did to do the job.
  1. Front mount intercooler
    By DTI Dave in forum Diesel Engine related
    Last Post: 2nd December 2011, 21:58
  2. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  3. Hi Front mount intercooler (fmic)
    By total_vxl in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2010, 19:21
  4. New front intercooler pics
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 18:35
  5. Spoons Vs Regal intercooler
    By dannysport18 in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2007, 19:26
vectra c fmic
vectra c 1.9 cdti intercooler upgrade
vectra c 1.9 cdti intercooler fitting
how to fit vectra c intercooler
vectra c front grill removalvectra c 1.9 cdti cooling system lyoutvectra cdti front mount intercoolerintercooler golf 4 tuningintercooler vectra cc vectra intercoolervectra c intercooler upgradevectra c front radiator grillvectra c 1.9 cdti fmicvectra cdti fmicare fmic better on a vectra than standard intercoolervectra c intercoolerSpoon intercoolervectra c grill more airflowfitting front mount intercooler vectra c 1.9cdti
