Thread: Lights problem - lights out
    Feb 2007
    Meath
    Eek Lights problem - lights out
    Hi all,
    I'm back again in need of a bit of help. I know I haven't complied with regulations yet but I'm hoping you'll overlook that.
    The front lights always seemed a bit dodgy to me, they would dim quite significantly when I put my foot down and the car had only just been started. I thought this was just a quirk of the car. Just recently, one of the right indicators stopped working intermittently. I couldn't find any loose connections etc...
    Now, the screen washer has stopped working and the wipers are behaving strangely. Normally, when I tap the stalk up once, the auto wipers kick in. When I do the same now, they only work when I hold the stalk up in the first position or I push up fully and they stay on. When I knock them off, they stay where they stop (don't return to normal position.)
    Also, the headlamps (low beam) switch themselves off after a few seconds and the computer kindly informs me of this fact. Oh, and the high beam stop working after a few pushes too...
    Has anybody got any idea what's wrong? I'm starting to think the car's possessed!
    Cheers,
    DarkNite
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by DarkNite View Post
    Me too ... sorry
    Feb 2007
    Meath
    LOL - Thanks!
    Just realised I've posted this in the wrong place too...
    moved it for you....
    the way that the systems are failing, i wonder if it's the CIM module failing as all the problems run Via the Column and it's PCB..Dealer only job to find out..
    Feb 2007
    Meath
    Thanks.
    Is a CIM expensive to replace?
    if it is at fault ( which only a dealer can prove) then get ready for a £350 odd shock....
    Feb 2007
    Meath
    Just to add a little extra to this really strange problem. When I switch on all the lights including high beam and they subsequently go out, the indicator starts flashing normally again and the washer/wipers return to normal - WTF!?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    just found this. it may help if it is indeed the cim....just need to make sure its the right one as he mentions two different years. cheaper than £350
    http://cgi.ebay.co.uk/Vectra-C-New-s...QQcmdZViewItem
  1. AFL & ABS Warning Lights - Problem
    By spoons in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 15:03
  2. Problem with my lights
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2011, 10:10
  3. lights problem
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2011, 15:36
  4. Interior lights problem
    By smoggy1955 in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2011, 14:11
  5. problem with rear lights
    By chris_20 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2011, 21:38
