Thread: Exhaust
    Mansfield, Nottinghamshire
    Default Exhaust
    Got a problem with one of the back boxes on my '04 2.0t petrol vec as it has a huge rusting hole in it!!!
    Can anyone tell me if you can just change one of the back boxes or do i need to replace both up to the mid section?
    If I have to replace both sides can anyone recommend what to get i.e. stick with vx std or get a magnex - be helpful with approximate costs too please.
    Thanks in advance
    Mark
    just replace the holed one, but i warn you, they're not cheap...like £150 +vat each for genuine one's.. when mine go i'm getting a powerflow system as it works out cheaper....
    Thanks for that - i dont suppose you know how much it is for a powerflow system and are you replacing the whole system or just the back boxes?
    TIA
    as and when i do change it will be from the catalyser back..had quotes around £350-£380..
    May 2007
    Aldershot
    Thumbs up Hello
    I have a six month old nearside rear silencer complete with chrome oval tip thats standard fit on the sxi / sri models.
    70 quid if you know anyone
    differs with engine size..
    morton
    are you sure its the exhaust and not just the shell ??
    yep, they are double skinned cans, but they rust inside out, so if the outer one is holed, the inner isn't far off..
    morton
    oh ! i must have got lucky then ! ( for a change )
    Jan 2006
    Skynet HQ EMEC#5
    My Powerflow system - single exit, from cat on manifold back was £360
    That included stainless flexible section & installing threaded bushing for oxygen sensor.
    It does vary between areas so worth checking
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
