Results 1 to 10 of 22
Thread: Noise from rear?
    UK
    confused Noise from rear?
    Hi am new to this forum.
    I have a problem with my Vectra 2L sri..
    It makes a clanking noise from the rear passenger side when driving some times while cornering but most off the time its when going over bumps. Its not the Exhaust as I have had a new one fitted and the noise is still there its like metal hitting metal.. Any ideas as to what this could be?
    Thanks in advance!
    morton
    broken spring ??
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Not a clue what it is but i have potentially the same problem, doesnt always happen but often will when cornering, and i have notes of exhaust being replaced and clamps too but still a knocking on the service notes.
    Sorry to butt in but id like to know what it is too
    There was a problem with early C`s which gave a clonking sound to the rear, it was a problem with the b or c pillar and was fixed under warranty .
    Mileage : 000
    Might be one of the supention bush,s Knackered. I have to change them on my Wife,s Vectra B.
    Aug 2007
    Great Wyrley
    Well i presume mines out of any warranty being an early 2003, is there anything i can do, or is it a major overhaul?
    the only way you'll ever find it out is to get the car jacked up and have a good look underneath with a prybar.. if it's not something you can do, then it's dealeer time..
    Aug 2007
    Great Wyrley
    what am i looking for? im ok with cars had several older cars which are simplier to use and fiddle with,
    Regular Member skinnyman's Avatar
    manchester
    Hi gregg, try to climb under the car with out jacking it up at 1st as jacking it will tighten all the suspension components (anti-roll bar drop-links, arms e.t.c...) try to wiggle anything that looks like it moves, sumtimes a small pri-bar helps find excessive play.
    Then car the car up and do the same. If its that noisey you will notice it straight away.
    Aug 2007
    Great Wyrley
    ok ill give that a go cheers
  1. Noise from rear
    By stanlee in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2012, 13:07
  2. Noise from Rear
    By DesignforLife in forum Bodywork & Interior
    Last Post: 21st December 2009, 19:35
  3. rear noise
    By themurf in forum Introduce yourself.
    Last Post: 19th May 2009, 15:45
  4. Rear Noise
    By johnK in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:31
  5. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
