Thread: brake sensor new disc and pads
    WALES ENGLAND
    Default brake sensor new disc and pads
    front brake sensor light came
    on today.do i have to go to vauxhall to get it looked at.had a good look at them and there is a lot of brake bust on wheels? hope they been fitted right.can any one give me any help reasion what going on.
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    Hey DECO, welcome. Depending on its age, I would just take it to your normal, local garage. The same happened to me, I took it in and found that the pads were fine. Some vec's have a fault where the brake pad warning light flashes for no reason, and the only thing that Vx do to put things right is to turn the sensor off.
    Hope that helps.
    WALES ENGLAND
    niceone mate ill do that.
    if you do need new pads, don't forget you'll need a new sensor lead as well, once they have worn down they need changing..
    [Ex]Admin Duncan's Avatar
    I think he has just had new pads fitted Mark, if I understood his post. So as you say it should have had a new sensor wire fitted. Looks like they've knackered the last one by trying to reuse it.
  1. pads and disc size
    By chris1804 in forum Handling & Braking
    Last Post: 31st July 2010, 21:08
  2. Fit brake pad wear sensor without removing pads?
    By James24 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2009, 21:41
  3. Brake pads sensor
    By s1nglef1sh in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2009, 21:45
  4. New Disc & Pads
    By AJA in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2006, 11:46
