Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: All that lovely air !!!!
    spoons
    Guest
    Default All that lovely air !!!!
    For some reason Vauxhall put a blanking plate behind the grill on a 1.9 CDTi engine which prevents ANY air getting through. Therefore the only air getting in is from the very top (just under the bonnet lid, and the very bottom)...
    Well not now.... look what I've gone and done.... cut it all out !!!
    Oooooops.... how did this photo get in here......
    [Ex]Admin Duncan's Avatar
    Is that not to make sure no water gets into the air intake? - bad news for a diesel.
    spoons
    Guest
    Good point.... dunno... doesnt the 3.0 CDTi have the same problem then ?
    EDIT:: Dont Watercoolers squirt water into diesel combustion chambers to improve performance on trucks ???.... I'm not saying thats what I intended lol... but how can it be that bad ?
    More a case of stopping water getting into the engine electrics when you are following fast moving traffic just imagine how much water is sprayed on your car on a wet motorway at 70 MPH
    spoons
    Guest
    Quote Originally Posted by Drinky View Post
    Errr... guys... the VXR and 3.0 CDTi all have open grills.... so does practically all the other vehicles I've ever owned... just not the 1.9 CDTi...
    You lot havin a laugh !!
    Would we do that Steve .............................................
    Quote Originally Posted by spoons View Post
    I believed all the diesels had a blanking bit on the grille over where the air intake is - to stop water getting in. The petrols are open grilles. Must admit, I've never seen one like that where it's totally blocked up!!
    Wouldn't think that would really be a problem, it's the rad/intake area that it's all going to hit first. On the petrol models the grilles are not blanked off so it can't be an issue.
    Lets see how dirty Steves engine gets !!!!
    spoons
    Guest
    I believed all the diesels had a blanking bit on the grille over where the air intake is - to stop water getting in..
    This is a good point though Duncan and I'm amazed it hasnt been raised before... but anyway, I would like to get to the bottom of this question thats for sure
    EDIT: Not that I intended to use the VXRD as a boat !!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I think water injection is just a mist/spray, the flap is to stop hydraulic lock where a large amount of water is sucked in and essentially water cant be compressed so the piston head hits a solid force and boom! It happened to my old mans 407 hdi. Petrol's work on a lot lower compression so there is less risk of damage. Also as you have a turbo you are actually sucking air in so this makes the risk higher. You can buy a connection/valve thing that goes in your intake to stop hydraulic lock, I have only seen it in the states.
  1. lovely day out .
    By chris1984 in forum General Chat
    Last Post: 4th June 2012, 18:05
  2. Ok here they are! My lovely VXI lol
    By John LE in forum Quick Photo Album
    Last Post: 2nd July 2010, 20:43
  3. What a lovely day I'm having!!
    By AndrewTi in forum General Chat
    Last Post: 24th September 2007, 17:52
  4. What a lovely day !!
    By spoons in forum General Chat
    Last Post: 31st July 2007, 19:50
