Thread: Advice needed on breathing
    Regular Member Itsallrover's Avatar
    Aug 2007
    in an M&S somewhere in the South West
    Default Advice needed on breathing
    Hi, I have recently picked up a 2002 Vectra Gsi. Would like to know whats best a panel filter or cone? Can anyone recommend anything as I have seen whats available but I dont wanna buy something ****e.
    Jul 2006
    General opinion is to avoid cone filters - there's not enough cold air to make any difference. Get a K&N panel filter, and derestrict the airbox (in the how2 section).
    HTH
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Having said that, I tried lots of filters in mine to see which gave the best result and found that the foam mushroom came up No1. On your's, you would do well to do as said because it's naturaly asperated. Also there may be a piece of plastic behind the upper grill, deflecting direct airflow. Remove that and you should get a bit of ram induction at speed.
    Aug 2007
    Quote Originally Posted by parapaul View Post
    HTH
    Thats good because the panel filters are way cheaper. I have looked in the how 2's and cant find out how to derestrict the airbox
    Jul 2006
    do it..... works fine in our 3.2's..
    Aug 2007
    Cool will defo do it - the box mods seems far too easy but I like it. Are you using a k&n too? Does the panel filter make any noise or is it just a cone filter which does that
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The performance panel filter may make a little more noise but it's negligable. Cones can make an amazing amount of noise though!
    Regular Member simon7257's Avatar
    reading
    my previous job included work on a rolling road and i found that the replacement panel filters worked well after all the manufactures spent a long time getting cold air in but cone filters can be better if you use a proper heat shield and get a direct air flow plus they sound better
  1. 3.2 , bad breathing , high idle , issues
    By biffbangpow in forum Engine & Drivetrain
    Last Post: 18th November 2012, 16:14
  2. a little advice needed please
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:11
  3. advice needed
    By taxidriver50005 in forum Bodywork & Interior
    Last Post: 1st June 2009, 15:30
  4. advice needed!
    By sotonjames in forum Detailing and Car Care Discussion
    Last Post: 9th August 2007, 18:18
  5. Am I breathing Right......
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2007, 15:12
can my vectra gsi 3.2 2002 be derestricted
best grill for air flow induction on vectra c gsi 2002
