Thread: oil light,
    Aug 2007
    gateshead
    Default oil light,
    Hey guys need some help,
    My oil light in the middle of the speedo display keeps coming on ive checked engine oil and its fine ,its strange because say i started it up and left it running it doesnt come on only when i start driving it it does .any ideas what this could be ?
    cheers guys john.
    Are you checking the oil from cold? If so you need to have the engine at operating temperature, then let the car sit for a little while after turning the engine off (to let the oil settle) before checking the level.
    If that's what you're doing then trying to think what else it could be.
    oil level sender breaking down, quite common.....
    just needs a new sender if the oil level is fine..
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    the wifes Astra is doing the same, oil light goes off very soon after starting but blinks every now and again while she drives, hopefully I'll be getting the pressure switch changed next week ,
    if it flashes as she's driving it needs the pressure testing first..the sender is a cheap first guess at it...it could be anything from oil surge all the way to a leak in the vacumn caused by the oil pickup pipe if a seal isn't working anymore..
    if it's just as she corners/brakes etc then i'd look at the level switch in the sump..
    Southampton
    had the level light come on earlier this week even though the level was fine. local vx dealer said he'd seen several faulty switches go and would need the car for 2 days to sort it out as it was a big job. Didn't sound like it was going to be cheap to me!
    But then hes said if it was just a once off to leave it - if it happens again they'll change it.
    Oct 2006
    Portsmouth
    WOT ! had my wife's Astra oil pressure switch replaced and my Vec last week. took 15 minutes tops , (with a HOT engine)
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
