Results 1 to 3 of 3
Thread: Improved handling on its way!!!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Improved handling on its way!!!!
    Got fed up with the poor handling on my Veccy C so have took the plunge and brought the following:
    http://www.europerformance.co.uk/pag...html?id=446268
    and the front strut brace as well from Regal. Already have PI springs (30mm drop) which I am told by europerformance should go well with the new shocks.
    Thinking about some wheel spacers to go with the above http://www.europerformance.co.uk/pag...html?id=411436 maybe the 10mm ones to try and reduce body roll a bit more.
    Has anyone else put spacers on and if so was it worth it? I know it with help fill out the arches a bit which will make it look better at the very least.
    Will left you all know the out come as to wether it was worth it or not.
    Regular Member danlat1415's Avatar
    Lancashire
    Let us know how the suspension goes. I'm after new all round, and haven't decided on a set yet. Keep putting it off due to cost.
    Not sure about the spacers though. Never done them for that purpose before.
    Jun 2007
    Calne, Wiltshire, UK
    There are a lot of nasty stories about Spacers.... Cracking and wheel overtaking you in the outside lane being one of them...
    Though Mostly from the 4x4 community (where I used to hangout before I had a Shower, and started to wear Anti Perspirant..... ) as they have greater Torque figures though the half shafts, and some spacers are just not to it.
    Cheers.
    Matt
  1. DEPO Headlights - have they improved?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2012, 17:21
  2. Egr blanking.is this an alternative/improved method?.
    By felixx in forum Engine & Drivetrain
    Last Post: 27th September 2010, 22:43
  3. Improved mpg
    Last Post: 18th March 2010, 21:40
  4. The new improved Cabby...
    By Mark The Cabby in forum The 'Off Topic' room
    Last Post: 25th May 2008, 14:10
