Results 1 to 10 of 11
Thread: DTi suspension v CDTi suspension
    Feb 2007
    work
    Default DTi suspension v CDTi suspension
    hi guys
    is there any difference in the SRi set up between the 2 cars? weight load etc?
    thanx
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Get someone with a DTI to take a look at there axle weight on the door shut. The setup is weight dependant. It should also show up in part numbers.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Give me one minute and i'll go and look at mine for you....
    Feb 2007
    work
    cheers dude
    i think mine is 1080 F and 980 R
    Jun 2007
    They are the same rating, 1075kg and 980kg.
    Are they the same fitting??
    Feb 2007
    work
    ahh cool thanx mate - so they are basically exactly the same springs and shocks?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Would have thought so, again someone who knows part numbers should be able to confirm this. I think Mark should know.
    Jun 2007
    I knw the springs are definately the same, i had a conversation with Mick at LMF about 6 weeks ago on this very subject. Not too sure in the shocks though.
    Feb 2007
    work
    thanx for all your help - if any1 can confirm 100% i'd really appricae it
    Aug 2010
    london,hounslow
    Default Which shock absorbers and springs for 1.9 cdti sri ???
    I had my shocks absorbers and spring replaced 3 months ago with fk ak sport coilovers and the mechani didn't put the rubber on spring hi said was not the same size and now i have a very loud noise coming from the front and rear suspension, anyway i dont whant to keep the sport suspension anymore, becouse is to hard and noise , can you give a advise about a soft and silent suspension.
    The car is a vec c 1.9 cdti sri 150hp.
    Thank you Mike
  1. Cdti suspension the same as 2.2dti?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2012, 05:04
  2. Suspension fitting(1.8 - 19.cdti.sri)
    By martyboy in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2011, 11:17
  3. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. 3.0 cdti sri front suspension
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2009, 20:00
vectra c differences in front springs between dti and cdti sri
