Thread: Cdti 150 Engine Problem
    Portsmouth
    Default Cdti 150 Engine Problem
    I have a 54 plate vectra 1.9 cdti and recently it has lost its power and seams sluggish. Nothing has changed like over heating , fuel consumption or warning lights.
    Gets sluggish in second gear and the engine sounds more like a tractor. Any help would be much appreciated.
    first things first matey, when was the last time you checked the engine oil level?
    Portsmouth
    Have been checking it every time i drive since this problem has started. Just re checked and oil level is fine
    Portsmouth
    any one ?
    Portsmouth
    Took the car out today and noticed that it only sounds like a tractor when accelerating. When idle it sounds fine and also can’t hear the turbo so wondering if the turbo pipe has split. Also the engine is warming up qiucker but not getting any hotter than it did before. Anyone had something like this before ??
    Admin plasma's Avatar
    On the Forum
    183 Post(s)
    Engine : 150
    Mileage : 74000
    sorry mate not a clue on this one
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Sounds like a split hose or cracked inlet manifold, I had a mate with a similar problem,
    Went out driving one day and it sounded rough after a few days of him cratching his head wondering why there was a lack of power and the engine sounded different the management light came on, took it to his dealer and it was the manifold,
    Worth a check
    Portsmouth
    Cheers for all your help guys.
    Will be going in on friday. Hopefully its nothing to bad.
    Dean
    DEWSBURY
    i had a similar problem the other wk on my 54 plate signum 1.9cdti 150, the spanner light kept coming on then it would loose power almost as if the turbo had gone, struggled to get above 2500 rpm, took it to the dealers turned out to be the erg valve and the diesel article filter was slightly blocked, got it sorted and touch wood its been spot on since.
  1. Vectra 3.0 CDTI engine code problem
    By sb1uk in forum Engine & Drivetrain
    Last Post: 31st August 2013, 06:17
  2. 1.9 CDTi - Have you had a problem with this engine or not?
    By Ian in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2013, 14:18
  3. Replies: 5
    Last Post: 25th January 2013, 17:44
  4. problem with engine
    By stroake in forum Engine & Drivetrain
    Last Post: 13th May 2009, 18:36
  5. V6 CDTi faulty engine problem update
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2007, 21:20
