Thread: Centre Brake light
    Jun 2007
    Cheshire
    Default Centre Brake light
    First of all I admire all the work eveyone seems to do on their cars, but as I am not an engineer, I am aiming for the Classic look! Also on reading the small print on the warranty, some modifications would make it nul and void!
    My centre brake light has gone green and I was wondering if I could remove it and clean it, or should I ask for a repalcement on the warranty. I have only had the car two months. Also I have repalced the door pins but I can't get the rear ones to sit at the same height as the front ones. Strange I know, but I don't really want too start taking the door panels etc off.
    Cirencester
    if its still covered on and there is no cracks the the brake light cover then go and get i changed under warranty
    the door pins problem is because they're not irmy ones prob....
    what I have had to do before on copy pins is to cut the rear one's down at the base by the height difference, as they only go down as far as a bend in the rod then stop, so a hacksaw is the only way....
    Jun 2007
    Cheshire
    Thank you Gsi 3.2 for your advice. I will try and cut them down with the hacksaw, or maybe invest in the irmscher ones.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Signum centre brake light
    By rob1981 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2013, 17:25
  3. Rear Centre Brake Lights
    By scrub29 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2011, 09:50
  4. Centre Brake Light
    By WilliamLX in forum Insignia car chat
    Last Post: 27th September 2010, 14:48
  5. Check 3rd Centre Brake Light
    By Downunder in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2007, 16:14
