Where can i run some wires from under the bonnet to inside the car?
Ive seen the hole behind the battery-but where do the wires come through inside the car? and how dya pull them through
tar
tar
2 wires r going from the battery to a switch on the centre console
Rocker switch for the fogs
cheers!
Right. I think a favoured method for that one is a wire coat hanger. You can bend the tip of one end into a small loop, loop a length of the cable through and push the loop end of the hanger through.
As for where it comes through, it should be in the area behind the glove box - which you'll need to remove.
oh yeah,thanks thats a good idea i will try that tommorow
When I put the wiring in for my sub, if you remove the glovebox, up in the top corner near passenger wing is a grommet.
If you look under the bonnet, lift cover where pollen filter is. Grommet is on right in corner of bulkhead.
I've just taken this photo from engine side, you'll see the sub power lead going through, hope it helps.
thanx a lot,i'll have a look and see which is easiest 2 get 2
Remove the glovebox as said then look in the engine bay on the passenger side and remove the grommet, very easy access from both ends as I had to do this to give my head unit a power source.
LS now has foglights!!
thanx i pushed wires through the hole like in the picture
Fogs all connected up now with my switch in the dash as well
Pictures to follow
FOG LIGHTS ALL DONE PICTURES
http://forum.vectra-c.com/showthread...095#post365095
Many thanx!!
