Thread: Side Window
    Larkhall
    Default Side Window
    My driver side window looks like its rubbing off something as its going down. It rumbles as well. Dealers say they cant find anything wrong
    noisy door gear??.. a bit of a grease job normally.....and as for the marks on the glass..deep scrathes or just where the door trim rubber has caught it??.. if it's the rubber a smear of silicone spray normally stops it..
    Larkhall
    its just like a smudge mark. got it sparkling this afternoon then after i had it down it came back up covered in streak marks!! is there anyway to fix it myself???
    clean the internal rubber right up as well as the glass, or if it smears from the outside then remove the outer seal and clean that ( AG vinyl and rubber cleaner) and it should be streak free for a while..
    Larkhall
    when the window is going down it makes a loud rumble, but it only smears when ive washed the car, obviously the seals are wet
    grease the door gear for the window, that should quieten it down.. and grease all the slides on the bottom of the door glass as well....
    take the door trim off and it's an easy job to sort out at home..
    Larkhall
    how do you take the door trim off?
    sounds like a job i could do tomorrow
  1. Drivers side window
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2011, 21:08
  2. drivers side window
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2010, 19:24
  3. Drivers Side Window???
    By mikeq in forum Bodywork & Interior
    Last Post: 11th February 2010, 13:18
  4. Chrome strips at the side under the window....
    By jalooije in forum Styling
    Last Post: 26th May 2007, 16:56
  5. Crome side window strips
    By Paz_37 in forum Styling
    Last Post: 26th April 2006, 19:27
