Results 1 to 10 of 16
Thread: 2.0 dti
    Regular Member howey's Avatar
    Oct 2006
    tyne and wear
    Default 2.0 dti
    for the last 2 weeks , it seems the vectra has been eating diesel , say if i put £10 a day in my computer would show that i had 110 miles till i needed more...now it shows about 80 miles ,anyhow picked my wagon up today and followed the wife home , there was black smoke comming outall the way home , about 3 miles , not loads enough to see if you were driving it yourself , but enough to notice it when i was behind it..? could the two be related ? and what needs fixing? hope all that makes sense
    Oct 2006
    tyne and wear
    forgot to metion that a spanner has started appearing now and then when you start the car but not every time
    Black smoke means a rich mixture so the diesel consumption increase is to be expected.. if it's got a spanner light then it's got a fault code stored.. get it read and you'll have more of an idea of whats wrong..
    Feb 2006
    Guttedsville
    Sounds suspiciously like a split boost or intercooler hose to me.
    Check the fat hoses at the front of the engine, make sure they are attached and not actually split.
    Does it feel a bit sluggish too?
    Oct 2006
    tyne and wear
    yeah it is sluggish..ill check that out when its light
    Oct 2006
    tyne and wear
    how much does it cost to get the faults read ??? is it main dealer only ?
    nope faults can be read by anyone with a CAN compatible code reader..normally £45 at a stealers but prices vary at independants..
    Oct 2006
    tyne and wear
    cheers for the info guys
    Oct 2006
    tyne and wear
    A BIG PAT TO ANDREWTI... its a split pipe....£95 at the main stealers....what i want to know will one off a vectra b 2.0 dti be the same????.......if you are looking at the engine its the one on the left that goes somewhere under the plastic engine cover
    fleet
    This sould like a "low blow" engine to me, as on the High blow, the hose is routed via an inter cooler,and has a a stainless steel pipe to direct aound the engine. A vectra B 2.0 DTi should fit, but always compare carefuly first.
    BR
    Andrew
