Thread: help required re 2.2 dti engine
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default help required re 2.2 dti engine
    as above my brothers 04 plate signum 2.2 dti is giving him grief and i wonder if anyone can advise what the problem is,the car has just had egr valve replaced as it was deemed faulty but gthe problem remains! the car basically drives fine then all of a sudden loses power and judders,not good on a busy motorway! but the car has been linked to tech 2 and nothing is showing up and cos the problem is intermittent its doing his head in,anyone else had this problem or heaerd of it ,and if so whats the cure
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    I'm sure AndrewTi might be able to suggest a few ideas - I'm sure he'll be on soon
    Feb 2006
    Guttedsville
    Sounds like the EGR valve wasn't reconnected properly or is itself knack'd.
    From there, I'd check the boost sensor wiring for breaks and give the AFM a good clean up.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Quote Originally Posted by AndrewTi View Post
    ill pass that on andrew mate cheers
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. URGENT help required. Put petrol in Deisel engine
    By Jake in forum Engine & Drivetrain
    Last Post: 25th September 2010, 15:42
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. Your views required or help required??
    By Colin S in forum Detailing and Car Care Discussion
    Last Post: 18th September 2008, 02:15
