Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: What would people recommend for a 1.8 petrol?
    middlesbrough
    Default What would people recommend for a 1.8 petrol?
    What would people recommend for a 1.8 petrol? either a induction kit or a panel filter.
    Regular Member cyb's Avatar
    depends on why..
    an after market panel filter (Courtneys, LMF, etc) will help improve the breathing.
    the induction kit will also give a nice induction sound.
    but neither will really give you much extra bhp.
    SCOTLAND
    i would go for a panel filter myself and when fitting you can remove a couple of plastic bits from inside the airbox to improve the airflow further.
    As cyb said though neither will ip the power much
    Graeme you now have me wondering is there a version of the '3 pipe mod' you can do on the vec C?
    middlesbrough
    thanks for that guys, thats a help in the right direction.
    Quote Originally Posted by cyb
    There is a pipe on the bottom under the filter which clips out, then on the top you can cut the pipe which goes in down flush as well.
    I thought you had a viper on though ??
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Personally on the Astra G - the panel filter worked well - but the filter and the engine block were closer together - but as a known good combination I would recommend it for the C.
    Just here!!!
    Smile
    So if i was to sorry to interrupt here guys but if i was to fit a full stainless steel exaust system and a viper induction kit this wouldn't improve the bhp.
    cus i thought it would would'nt you say?
    iwas told the other day from a guy who specialises in these type of things that if your going to fit a induction kit to your car then you also need to change the exaust to get full gain out of your induction.
    or you could alternativly change your back box instead.
    i don't know how accurate this info is but it sounded pretty good.
    something to do with the vauxhalls back box being chambered and a example:scorpion: not being chambered so it can release the exaust gasses alot quicker as the engine sucks it in.so they work together.hope this helps .
    Quote Originally Posted by payney
    I firstly mis-read the Andy's question - and started listing inlet manifolds, remaps, exhausts decatting etc - but then re-read his last line -
    Just here!!!
    Quote Originally Posted by kitchpoo
    hey carry on m8 its always good to learn more about wot u can do.
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. Recommend me a new car!
    By KeefyB in forum The 'Off Topic' room
    Last Post: 1st September 2010, 20:10
  3. what would you recommend
    By WKD-mcc in forum Detailing and Car Care Discussion
    Last Post: 11th March 2010, 10:10
  4. recommend me............
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 22:32
  5. I recommend these
    By P3tchy in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 20:25
