Results 1 to 10 of 20
Thread: Fitted Reversing sensors
    Regular Member wardy's Avatar
    Chichester
    Default Fitted Reversing sensors
    Well, finaly got round to fitting the £16.99 kit from Techsales Uk, and I'm well impressed! Even though the instructions stated minimum height from ground of 50 CM, I fitted to the grey part under the bumper (Estate) at about 35cm and it works fine! That may be in part due to the grey pannel pointing slightly upwards. The alarm has two volume settings, and I've found it to be powerfull enough to site it next to the rest of the kit in the rear pannel.
    Also not had to use any relay, as the bulb check feature does not trip this system.
    Found an easy way of feeding the cables in through an existing blank rubber grommet that is in the little storage area between the spare wheel housing and the rear bumber. Had to remove the linner, and the strike plate, but that was very easy to do. Also there are two earthing bolts in there so no need to drill holes & use self tappers etc to get an earth.
    The kit I went for is the alarm only kit as I didn't like the look of the LED / LCD dash systems (and I'm tight ).
    Decided to paint them, as out of the Box they were too gloss black & would have looked odd against the grey matt plastic. But i think the grey I chose was probably a little too pale, but not bad.
    Particular thanks to ghostrider, who told me which wire to "tap into" for the reversing light (as the lights are in the tale gate of the estate) and that saved me loads of time.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    top job m8, they look realy good, well done
    Midlands Mod Shop - NFFC.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Looks good!
    Have not got round to ordering some for mine but will do this week.
    member of the smoke patrol 230bhp+
    a very good price
    birmingam
    hi, can you tell me how to tap into the reverse light feed as ai need to fit some on an estate also...
    Surrey
    Looking good?
    Black and white wire isn't it?
    birmingam
    the how2 guide shows it in a different place to the wot ghostrider is stated.??
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Looks good!
    Chichester
    Quote Originally Posted by pally View Post
    The estate is totally different wire to the hatch/saloon. It is as Ghost rider stated for the estate.
    Chichester
    Check mine & Ghostrider's posts on this link
    http://forum.vectra-c.com/showthread.php?t=51831
  1. reversing sensors
    By redo in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 19:27
  2. Should have fitted some reversing sensors
    By lofty in forum General Chat
    Last Post: 1st May 2010, 07:23
  3. Reversing sensors finally fitted.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2008, 16:47
  4. Anybody fitted these reversing sensors
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 20:40
  5. reversing sensors fitted
    By ditchp in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2007, 22:44
