Results 1 to 10 of 15
Thread: Help - Sri 'apron' removal !
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    confused Help - Sri 'apron' removal !
    Hi all,
    I've recently bought and painted the vxr apron (the bit that goes between the exhausts) and i'm struggling with removing the SRI grey one. I don't want to get violent with it incase the new piece wont fit either!
    Thanks in anticipation.
    Jul 2006
    Mexico
    Don`t know much about SRI but might be similar to mine....you have to take off 2 torx`s on the back wheel arches. 2 on each side....
    Then go under the boot and there should be to plastic brakets that need to be taken off, the gently pull out the plastic starting from the wheel arch and work you way from one side to the other....hope that`s clear enough
    HTH
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Quote Originally Posted by Dr. Direct View Post
    Hi all,
    i found the best way was to remove the 6 plastic inserts underneath by pushing the centre pins straight through then starting at one end slide a thin knife through each lug hole from the top and from the outside of the bumper thus depressing the lug.Whilst at the same time applying a gentle pulling action on the "apron" thus releasing each lug in turn until you reach the other side.
    Hope this helps
    P.S I discovered this technique after i`d already bust mine in two
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    im afraid its a case of a sudden tug at it, i had the same problem with mine
    Widnes, Cheshire
    Quote Originally Posted by 3.2_V6_VXR View Post
    So if I stick a knife into each on the clips, and just pull it??
    It scares me stuff like this!! Give me a air filter to change any day!!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Leave it in the sun for a bit,it'll warm it up a bit and make it more flexible.
    May 2007
    Sheffield
    slide the knife between the apron and the bumper through the holes where the lugs go and it will push the lugs down.At the same time pull the end of the apron( gentle but constant) until each lug pops out working your way to the other end.The knife does nt leave any visible marks on your bits.
    member of the smoke patrol 230bhp+
    iv ever seen one come off with no damage so dont worry about it getting damage,,,
    you have a nice new one going back on
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Pop the 6 rivets out as said, then get a bit of rag and put it on the bumper, then prise the apron out from the outside with a small screwdriver. Put the rag between the screwdriver and bumper when you prise it out, and no damage will occur. Did mine last weekend and thats how we got it out, and the old one came off in 5 pieces!!
    Washington
    Yes very tough to get this apron off, the 6 rivets and 2 clips are fine, but the lugs/teeth are a biatch.
    Broke my apron off into 3 pieces after half an hour pulling, twisting and scathing my hands.
    You'll need alot of patience and gloves may help. Good Luck.
  1. VXR Lower Apron
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 22:26
  2. removing the SRI apron?!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2007, 17:56
  3. vxr rear apron
    By brucie boy in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 01:10
  4. rear apron (sri)
    By armoured farmer in forum General Chat
    Last Post: 31st October 2005, 00:07
