Results 1 to 10 of 17
Thread: Oil Consumption
    Nov 2005
    North
    Vehicle : Vectra 3.2 V6
    Trim : GSI
    Engine : Z32SE
    Mileage : 77500
    Default Oil Consumption
    Hello
    I'm putting in about 1 litre of oil every 150 - 200 miles and its costing a fortune.
    Anybody having problems with oil consumption on a 2.2 Petrol?
    SCOTLAND
    i've had a few niggles but nothing as bad as that mate. maybe worth getting it checked out? i believe the 2.2 can be quite thirsty but as i say i havent ever used that much. have you tried putting a bit cardboard under at night in case its a leak?
    Nov 2005
    North
    Trim : GSI
    Engine : Z32SE
    Mileage : 77500
    There isn't any visable leaks and no oil smells.
    Its just been back to vauxhall and they didn't find anything which could be causing the oil consumption.
    Only had the car a month, and im not impressed and It doesn't seem to perform better than my old-shape 2.0 140 SRi
    Sunny Aberdeen
    Hiya Rossy,
    My 2.2 hasn't used a drop of oil in between my regular checks. As Graeme suggests get a bit of cardboard under it SURELY there must be a leak using that amount of oil. Any blue / black smoke out the 4r5e end ?
    Mileage : 000
    could any of the breathing pipes be blocked with emulsified oil[short journeys], it may then force the oil past the piston rings as there is a lot of crankcase pressure,, probably not the cause, but just an idea anyway...
    ed taylor
    Regular Member ion's Avatar
    walsall
    As RBK says, surely must be a leak. To burn that much oil would stink & smoke like hell.
    Nov 2005
    North
    Trim : GSI
    Engine : Z32SE
    Mileage : 77500
    Its been into a Vauxhall dealer today.
    They have found it to be burning oil from cylinder No 4 and require it back next week for the cylinder head to be removed to see if its a cylnder head or bottom end problem.
    This should not be happening to an engine with 34k on.
    walsall
    Quote Originally Posted by Rossy
    Am surprised at that mate.
    Best of luck with it.
    Is it under warranty? Must be if you've not had it long?
    Let us know how you get on
    Nov 2005
    North
    Trim : GSI
    Engine : Z32SE
    Mileage : 77500
    Ive had it for 1 month. Network Q car.
    Yes, under Vauxhall warranty until March and Network Q warranty until next October.
    Should be all sorted then mate. :-)
  1. CID & Avg Consumption?
    By Welsh_J_2000 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2012, 01:06
  2. oil consumption
    By otto in forum Engine & Drivetrain
    Last Post: 1st February 2012, 22:37
  3. Oil Consumption
    By johnnyallen in forum Engine & Drivetrain
    Last Post: 23rd June 2010, 21:31
  4. How much oil consumption is too much?
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 19:38
  5. 3.2 consumption
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 20:17
